Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Hybrid View
    Nov 2011
    EU
    Default Passat edc17, problem with ecu after obd writing
    Hello
    I have problem with Vw passat 2.0 tdi 140 hp manual 2009 year.
    ecu hw: 03L907309
    I read this ecu with galleto via obd. All was ok. I made egr off file and write it without a problem via obd on ecu.
    Now after 3 months I tried to do also some dtc off on this ecu, I used my old obd read file, mod it and write back to ecu. Than I get error at end of writting and car does not start. (Customer was on official service 1 moth ago, he told me now)
    Now I attached ori file readed by obd 3 moths ago and my full boot read.
    Thanks for any help
    Jul 2012
    I think your file egr off is wrong ..
    Depending on what maybe the problem is the miscalculation of cks in the second writing ..
    you try to write the file that worked before though egr is not off to 100%
    Nov 2011
    EU
    I tried at least 10 times. Every time error...
    Jun 2013
    EU
    Updated ecu at dealer, t-prot active now. Seems not hard to guesss what have happend.
  5. The Following 2 Users Say Thank You to morgano For This Useful Post:
    antonypaul (22nd April, 2015), ecutuners (21st April, 2015)
  6. #5
    Nov 2011
    EU
    Yes... If knew before that car was at the dealer. I would not do that... What should I do now?
  7. #6
    Jun 2012
    Tprot not active. Maybe if you can check with VCDS date of last flashing (if it was flashed at dealer)
  8. #7
    Nov 2011
    EU
    Tuesday,21,April,2015,18:37:51:04354
    VCDS Version: Release 14.10.1
    Address 01: Engine
    Control Module Part Number: 03L 906 022 QC
    Component and/or Version:
    Software Coding:
    Work Shop Code: WSC 00000
    VCID: 76E3E5D101D63F9144C-8023
    Flash Status
    Programming Attempts: 10
    Successful Attempts: 2
    Programming Status: 10000000
    Required Conditions: 00000000
    Flash Tool Code: 00032 257 66565
    Flash Date: --.--.--
    Misc.
    Hardware number: 03L 907 309
    VCDS Info:
    Labels: 03L-906-022-CBA.clb
    Readiness: No script available
  9. #8
    Nov 2011
    EU
    03L906022QC 3732 I need this file.
  10. #9
    Jun 2012
    Write by boot , let the tool make chks.
  11. The Following 2 Users Say Thank You to wiski For This Useful Post:
    antonypaul (22nd April, 2015), bugarcek (21st April, 2015)
  12. #10
    Nov 2011
    EU
    Still error at the end and car does not start
  13. #11
    Nov 2013
    UK
    Your original boot mode backup you can't write it? I can help with this....
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
  14. The Following User Says Thank You to tunertool For This Useful Post:
  15. #12
    Nov 2011
    EU
    I do not have original boot mode backup... I boot mode read after obd fails.
  16. #13
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    You can try to write these file
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
  17. The Following 3 Users Say Thank You to kire106ka For This Useful Post:
    antonypaul (22nd April, 2015), bugarcek (22nd April, 2015), LinusLinus (14th August, 2016)
  18. #14
    Mar 2020
    Default passeord
    Quote Originally Posted by kire106ka View Post
    HI i have the same problem, can you give me password to open files?
  19. #15
    jurebv's Avatar
    Dec 2017
    Croatia
    their files wont work for you...upload your boot and obd
    2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
    FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
    Official Magicmotorsport Distributor
    Official Autotuner Distributor
    Official Alientech Distributor
