Results 1 to 12 of 12
    Sep 2009
    Default A6 2004y dash swap ?
    hi,
    i need to swap dash audi a6 2004y MM 4F0 920 900S with dash a6 MM 2006y 4F0 920 930C , after install i have SAFE on lcd and fault code component protection active , can some one please copy CS from original dash file to remplacement one both are 95160 eprom.a6.rar
    thank you.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Adaptation via obd2 only, with AVDi/FVDI or ODIS online.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    Sep 2009
    i did try with fvdi but need gatway eprom original from car that came replacement dash wich i dont have to verginise .
    can original avdi do it without need of gatway eprom ?
    Apr 2010
    yes do it without gateway
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by branimirj View Post
    No it can not, You have to have Can Gateway form car that you installing cluster. You do not need to have one from replacement cluster.
    Apr 2010
    No need any gateway all job via obd i replacement 2 dashboard.pozdrav
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    If car gateway cannot be read via obd2, then software will ask about dump. You need ONLY gateway from car that you install dashboard.
  8. The Following User Says Thank You to lupu_sandu For This Useful Post:
    yugo45 (23rd April, 2015)
  9. #8
    yugo45's Avatar
    Apr 2010
    Yes it does, but like LUPU said if read automatic form car then it will not ask for it.But in some cases will ask you to load CGW eeprom dump.
    With out Can Gateway not possible to adopt new cluster or have this AUDI work with anything.CGW is the bran of the car for information.
  10. #9
    Mar 2010
    US
    Also, use FVDI V18. If using V21, there is a bug with CP and will not adapt to GW. GW read/flash by OBD2 fine with AVDI/FVDI 18 on 2004 A6. Only some newer GW not supported by OBD2. I have genuine AVDI, but had this issue/experience with FVDI in the past as well.
  11. #10
    Sep 2009
    ok today did read eprom 95320 from car gateway use fvdi same probleme cant virgine second hand dash it ask for dump from gateway in car from came second hande dash .
  12. #11
    yugo45's Avatar
    Apr 2010
    You need to use first option , by OBD.
  13. #12
    Sep 2009
    Quote Originally Posted by yugo45 View Post
    i did first time same error .
    now find same dash i swap eeprom got safe and def 999999 in odometter display what do i need to swap also ?
