ZGemma H1 OpenATV 5.0 Backup
Installed:
Crossepg 0.81 (Tested working with Rytec and openTV providers) **USB Pendrive Required**
EPGRefresh 2.0 (Tested and setup to capture VM EPG) **USB Pendrive Required**
Autobouquets C2 Lite (Available from Plugin menu DVBsnoop installed remember to do a full DVB-C scan first before use)
Autobouquets 2.0 (Tested and working with Sky SD and Sky Ireland SD channels)
Cams:
C**** 2.3.0 (Installed and tested working with a correctly configured C****.cfg file if needed)
M***** 1.38 (Installed and tested working with both c*****.list and n******.list simultaneously)
O****_atv_emu 10639 (Installed and tested with working softcam.key for Multisat use. for webif please use 192.168.xxx.xxx:5000)
Please Note:
before using Cable Autobouquet you will need to set your Net ID in the Service Searching menu and then do a full manual scan before you run the Autobouquets C2 lite Plugin.
Satellite Autobouquets will also need to be changed to your own AREA code, Please also change the Sat Config from Multisat to single.
Installed:
Cams:
Please Note:
https://mega.nz/#!UwBgHY7R!GJn-9NswCRjK9zF-X6lKr_fV1lVcIf4JTOwiJXRpLj0
