Results 1 to 4 of 4
Hybrid View
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Default Vovo C30 1.6 EGR Problem
    Hello friends !! I have a big problem with the Volvo C30, Bosch 0281011775 1.6 2007 , after removing EGR and programmed with BDM100, error appears in ABS "p0101" communication with ECU !! done it before this car, but the problem always resolved by working with "Kess".
    I tried to write files golds, using BDM100, but error appears after a few seconds !!
    perhaps corrupted file ORI ??
    failed, to correct file Ori ?!?
    I can write Flash files golds with "Kess", but I read it with BDM100?!?
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    kire106ka's Avatar
    Aug 2012
    MACEDONIA
    Write bdm these file
    IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
  3. The Following User Says Thank You to kire106ka For This Useful Post:
    centrohifi (24th April, 2015)
    wiseman's Avatar
    How you mean you resolved with KESS? Wire on bench?
    I have had this problem also and it is a nightmare. With fgtech, bdm etc... Always has anti skid come on dash. Creates a fault somewhere in between Ecu-central electric-Abs. Anyone else have this ?
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    I, a month ago, I worked on this unit, before programming, appeared ERROR ABS !!
    Write ori flash gold, and error went away !! then I tried to re-program a new File "ECU Vonix service no dpf" error went away !!
    I do not know, it seems to be an error of CHK !!
    this C30, I have to remove EGR !! but error remains, even with file ORI !! Now try other files, and say
