Results 1 to 15 of 18
Thread: focus DPF OFF
    Top Poster krimo06's Avatar
    Mar 2011
    maroc
    Default focus DPF OFF
    hello
    i have problemme whith ford focus ECD16C34 of DPF
    i use volta,ecusafe ... but no resulte
    can any one help thank you
    nizarben's Avatar
    Dec 2013
    Default dpf ok
    try this report plzz
    mp
  3. The Following User Says Thank You to nizarben For This Useful Post:
    krimo06 (24th April, 2015)
    Mar 2011
    maroc
    THANKS for fast reply i will try now
    Feb 2015
    Suraj
    DPF Off all sensor disconnect connector
    EGR Off disconnect connector
    Additive Off disconnect connector
  6. The Following User Says Thank You to Prime For This Useful Post:
    Mar 2011
    maroc
    Quote Originally Posted by nizarben View Post
    mp
    not work friend
    i have desconnect all
  8. #6
    Mar 2011
    maroc
    any one can help !! i need it urgent !! thank you
  9. #7
    monitel_service's Avatar
    ROMANIA
    Another solution is to learn to fix that car
  10. #8
    Mar 2011
    maroc
    what solution can you help
  11. #9
    all sensor conected. switch solution
  12. The Following User Says Thank You to gma222 For This Useful Post:
    krimo06 (25th April, 2015)
  13. #10
    Mar 2011
    maroc
    I will try now
  14. #11
    Mar 2011
    maroc
    not work !! friend
    also has additve problemme have other solution plz
  15. #12
  16. The Following User Says Thank You to gma222 For This Useful Post:
    krimo06 (26th April, 2015)
  17. #13
    Nov 2013
    %100 working solution; disconnect the connector of exhaust temperature sensor and differential pressure sensor.
    Pass in PM.
    Ford_Focus_1.rar
  18. #14
    Sep 2014
    What fault codes you have ?
    there is a switch solution in this ecu, very simple. maybe there is other problem with your car?
  19. #15
    Mar 2011
    maroc
    the problemme is additive and fap
    juste this and all this solution is not work if some one have a tested one plz
