Results 1 to 12 of 12
    Feb 2011
    Default Solution control torque Mercedes Delphi
    Disable continuous monitoring on the engine torque output (Torque Monitoring Management), usually associated with error or P061A P061B, allowing larger increments and without restriction during calibration of new maps.
    you can know the solution free for all?
    LaraVAG's Avatar
    Jun 2011
    Poland
    there are some hidden limiters in Delphi CRD Sprinters ECU.
  3. The Following User Says Thank You to LaraVAG For This Useful Post:
    ernesto90 (27th April, 2015)
    Feb 2011
    WE HAVE A solution to this file ?
    Feb 2011
    Brand derivation of the file : MERCEDES
    Model -derived file : B CLASS W246
    Type derivation File : B180 CDI 1.8L 16V 80kW / 108HP CRD3.XX
    Protocol derivation of file : FLASH_0366 MERCEDES DELPHI CRD3.X
    Hardware Number : 6519040301
    Software Number : 6519026400
    Data Hardware:
    Data Software :
    Frame: WDD2462001N004997
    Software version :
    Replacement number : 6519010601
    Engine Number :
    Hardware Version :
    Software update : 6519030707H
  6. #5
    Feb 2011
    news? for me?
  7. #6
    Aug 2012
    Quote Originally Posted by ernesto90 View Post
    upload your mod and ori :-)
    or better post your ols
    or
    Nm conversion make it stock
    after torque limiter by pressure is two another torque limiter
    and 1 single limiter :-)
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
  8. #7
    Feb 2011
    [QUOTE = icezero2010; 2.518.189] caricare il mod e ori:-)
    o meglio inviare i vostri oli o conversione Nm rendere magazzino dopo limitatore di coppia da pressione ? due un'altra limitatore di coppia e 1 singola limitatore: -) [/ QUOTE]
  9. #8
    Aug 2012
    english or german please this is not your full mod . send your file with the error
  10. #9
    Feb 2011
    Already with this file by mistake
  11. #10
    Aug 2012
    you have only chance I_C_FUEL_PULSE_O***ET_REF_APM
    This map gives the pulse period o***et added to the the minimum pulse to give the required fuel quantity at the given Rail pressure.The map are indexed by each data indicated in the Y_Input definition, the main data being the first in the list.
    and this is too much :-) you don?t need this map i have never chance.
  12. #11
    Jul 2013
    Quote Originally Posted by icezero2010 View Post
    or
    Hello,
    I have the same problem on my c180, I copied all increments from a c220 that differences only on some maps and creates torque error. You may check please ??
    PHP Code:
    https://www.sendspace.com/file/6idsck
    Thanks in advance...
  13. #12
    Jan 2010
    Why cange only injection map? you got the axis right , but strange area to modify, no use under 1800 rpm
