elmer9 (19th May, 2019)
very nice,
a question, the big one,
https://www.mouser.it/ProductDetail/...pw6a7XZQ%3D%3D
is it marked 220 uF is it correct or is this also from 22 uF?
224 = 220 uH
220 = 22 uH
What part is this marking on. I don't understand the question well. About 4,7 uH.
Where is this coil? The coils on China clones are good, it's useless to change.
on the photo for reworking components is indicated large inductor with code
MSS1260-224KLD
https://www.mouser.it/ProductDetail/...Y0Ewpw6a7XZQ==
the value of the image is 472 and not 224, is it okay?
But these are just illustrative images. The value is written in the description. Coil 220 uH has a marking of 224.
elmer9 (21st May, 2019)
Program you can find On official fdti website, ftdi uttilities section
https://www.ftdichip.com/Support/Utilities.htm#MProg
MProg 3.5 - EEPROM Programming Utility
MProg 3.5 older program is replace now to FT Prog, but still both works.
FTDI KESS data
1. You can download/read ftdi data from exist working kess or try found on internet...
2. But i cant find from 5.017, so i found from kess 4.036, and pack name was someting like kess 4.036 sd-card content. They was sd image or content including ftdi firmware and mpprog.3.5, i can share both files later when i back home (evening)
But with my experience.
I have 2 kess clone 5.017 and both using 2 diffrent fdti data, configuration, so if some reason will dont work on one than need try to another.
My post helps you? Please Hit Buttons
elmer9 (22nd May, 2019)
No. No need desolder fdti. All you do soldered, the same with new chip, solder New chip and programm via usb.
All this elements is Cmos chips. But dont sure now the codes. Will tell you later and share dontent tonwrite ftdi
yes, share the file
with FT Prog I can't detect anything
I try with mprog
you have to explain to me how to proceed
1) USB cable connection to the kess
2) I open mprog 3.5
3) I click "Device" then "scan"
4) I click on "read" and "read and Parse"
5) then I click on "file" then "save"
it's correct?
yes see the same, FT PROG dont detect my FDTI chip, but MP PROG yes. (stange)
Yes how you said point 1-5 is all correct
look atachment there is 3 EPT files
P.S dont change the name files *.ept, from unknown me reason when i changed one files name than i can`t open in MP PRog, was some faults
The same if you like experiments with setting/configuration, this ept files only possible to change is open via notepad (can`t change settings in MT Prog program)
Col19 (30th January, 2020)
elmer9 (23rd May, 2019)
this my 5.017 file
kess ftdi.rar
please write me the names of integrated codes U13, U15, U16, U17
Tranks
