Page 114 of 127 FirstFirst ... 1464104109110111112113114115116117118119124 ... LastLast
Results 1,696 to 1,710 of 1894
  1. #1696
    Junior Member yoni13's Avatar
    Sep 2019
    In my House xD
    Quote Originally Posted by tkmmazda View Post
    The price is good. I also have one for sale for 180 Euro. Sophisticated and tested on several cars. I wouldn't be scared.
    Hi, I already received your Kess V2 Reworked, K-Suite installed, tested and everything works fine. Thank you very much for this unit! Rep+++
    New user of the Chip Tuning world!
    Kess V2 Reworked
  2. #1697
    Feb 2020
    Greece
    Deleted post
  3. #1698
    Jan 2019
    3D stickers available again. Sticker "Alientech" and "K"
    Post # 1524
  4. #1699
    Jan 2019
    Post # 1524
    1pc Kess v2 reworked ready for work and for sale.
  5. #1700
    hello
    I have soldered Crystal very smal 3.2mm lenghte it good?
    CSTCE8M00G15L99R0 orginal 7.2 mm lenghte
  6. The Following User Says Thank You to kenancatli For This Useful Post:
    boxsport (1st April, 2020)
  7. #1701
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by kenancatli View Post
    hello
    it seems to be all good.
    Nice job.
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  8. #1702
    Apr 2020
    UK
    Default Kess 2 v1.89
    To everybody that still has not managed to repair the K-line, I post my final transistor configuration that works perfectly, with transistor numbers included. If this helped someone click thanks
  9. The Following 4 Users Say Thank You to saoron2002 For This Useful Post:
    boxsport (27th May, 2020), Brandi (9th October, 2020), Col19 (25th October, 2020), hbalazs (16th July, 2020)
  10. #1703
    Hello
    Kess v2 5017 red pcb online version
    Reworked
    Mercedes sprinter w906
    Delphi crd3.20 Id read ok
    Reading file : error while transferring data in reading. Not success
    I have done software 2.47 and 2.53 not success, what it problem?
    Iaw 4af all ok
    Edc15p all ok
    Edc16c39 all ok
  11. #1704
    I try also ktag not success
    I find no on ktag crd 3.20 .
    I try under delphi crd3.40
    Not success
    Help please
  12. #1705
    Jupiter199's Avatar
    Feb 2016
    Not success
    Help please
    Send me please "All LOG" from you KESS.
    KESS, KTAG decoding LOG files - solved.
  13. #1706
    Jul 2019
    did any one have new software
  14. #1707
    PelsonBMW's Avatar
    May 2020
    Eu
    Hey ! i try to read Siemens MS41 with Kess and no success , i have error " ERROR WHILE TRANSFERRING DATA IN READING" and even on bench connected ECU i have the same error :/ what should i do ? , this topic has so many sites i couldnt find anything
  15. #1708
    Feb 2017
    Default update kess2 v 2.6 clone
    buenas tardes kess v 2.6 clon c puede actualizar a una versión más nueva si tiene la versión actualizada ayúdeme
  16. #1709
    Hi Guys,
    i am currently toying with the idea to buy a Kess V2 EU Clone.
    The Seller put this PCB in his auction:
    https://ae01.alicdn.com/kf/HTB12OiLb...663524ff40ca71
    and this Specs:
    1.the left upper corner and the lower right corner notch size is not the same
    2.Extra buzzer
    3.WFs = Infineon, BCR112 NPN Digital Transistor
    4.27E = ON Semiconductor NUP2105LT1G
    5.6DW = NXP BC817,215 NPN Bipolar Transistor
    6.A6c =MMUN2113LT1G / MMUN2113LT3G
    7.K5B = BC807-25-7-F PNP Bipolar Transistor
    8.Using imported Japanese Murata filter NFE61PT472C1H9L
    should i give it a try or search for another one?
    Greetings
  17. The Following User Says Thank You to Zund For This Useful Post:
  18. #1710
    Jan 2019
    Quote Originally Posted by Zund View Post
    Hi Guys,
    and this Specs:
    2.Extra buzzer
    Greetings
    Even if the board you get, comes with those components, you should ALLWAYS do the Rework to be sure the main components are OK...
    Otherwise it will be a flip coin if it works good or not...
    The one i bought came and it worked OK even when i didnt made the rework on it. and it seems to have the Originla components they claim...
    But at the end i replaced them all just to be sure...
  19. The Following User Says Thank You to boxsport For This Useful Post:
    Zund (30th May, 2020)
