Page 115 of 127 FirstFirst ... 1565105110111112113114115116117118119120125 ... LastLast
Results 1,711 to 1,725 of 1894
  1. #1711
    Hello
    Simos pcr2.1
    It can unlock and read and write with kess v2 5017?
  2. The Following User Says Thank You to kenancatli For This Useful Post:
    ASCM (5th June, 2020)
  3. #1712
    Jan 2020
    Ok, so i bought a Reworked Kess V2 and just have i few questions.
    -Is it K-suite i should install to Read & Write files via OBD2 ?
    -do you know any good Filesservice database that have good prices and good files ?
  4. #1713
    Jan 2020
    Ok so i have found some filesservices, but anyone know about the software ? Is it K-suite that is the easiest software just for read and write ?
    Quote Originally Posted by gillekille View Post
  5. #1714
    May 2020
    kess v2 help
    I have a kess v2 master version clone green board any good updates on SD card? i cant access K tag. Any other help would be appreciated, Thanks.
  6. The Following User Says Thank You to seat1234 For This Useful Post:
    boxsport (14th July, 2020)
  7. #1715
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by seat1234 View Post
    kess v2 help
    if you want to do the SD card using a better one, check this thread:
    https://www.digital-kaos.co.uk/forum...-a-new-SD-card
    if what you want is some kess firmware updates, then it will depend on the version you have and the $$$ you can spend...
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  8. The Following 2 Users Say Thank You to boxsport For This Useful Post:
    Brandi (9th October, 2020), seat1234 (15th July, 2020)
  9. #1716
    May 2020
    My Kess is 3.099
  10. The Following User Says Thank You to seat1234 For This Useful Post:
    boxsport (15th July, 2020)
  11. #1717
    Jan 2019
    My Kess is 3.099
    I think you can buy kess upgrade kit (nxp + sd card) so that you can upgrade to firmware 5.017.
    Not sure if you need to do any rework on your pcb, but probably some more experienced users can help you out with these doubts...
    You can find upgrade kit in AliExpress or probably someone here can sell with good quality SD card
  12. The Following User Says Thank You to boxsport For This Useful Post:
  13. #1718
    May 2020
    I'm willing to pay for a good quality SD card for my kess V2 master ultimate token version FW 3.099 and M board
  14. #1719
    It seems all links have disappeared by now, so i hope someone can post the following:
    4.024 bin + hex + sd-card + KessV2 sw that goes with 4.024.
  15. #1720
    Jul 2018
    Hi every one,
    maybe someone can help me? I bought a kess V2 5.017 clone from china. Worked good. one day i get on my Touareg EDC16CP14 Wake up error. After that i made the rework and also tried the solution with new good sd-card. But the issue is the same.
    Speed minimum and Pull up resistance in options i tested.
    tested on Mercedes A class with no problem.
    tested on Golf 4 1.9tdi not work
  16. #1721
    Aug 2020
    Default reworked clone
    Quote Originally Posted by csw03 View Post
    Hello, you can contact me
    your pm is full looking for a reworked kess from trusted supplier thanks.
  17. #1722
    mrjay88's Avatar
    Apr 2018
    UK
    post deleted
  18. #1723
    Mar 2016
    how to view picture on this forum
  19. #1724
    Aug 2018
    [QUOTE=nojmi7;3245376]Hi guys, I bought kess v2 5.017 and ktag 7.020 red pcb, I have mixed thoughts about the operation of these devices, must rework?
    Can anyone tell me wich parts needs to be replaced to rework this pcb ?
  20. The Following User Says Thank You to share112 For This Useful Post:
    boxsport (3rd September, 2020)
  21. #1725
    Jan 2019
    [QUOTE=share112;3945982]
    Quote Originally Posted by nojmi7 View Post
    Hello there.
    In my opinion, being a clone you should always do the rework and for Kess/Ktag you should also make new SD cards using a Good SD Card
