Page 122 of 127 FirstFirst ... 2272112117118119120121122123124125126127 LastLast
Results 1,816 to 1,830 of 1894
  1. #1816
    Jul 2016
    Denmark
    Quote Originally Posted by gas43 View Post
    Are you asking about SK14-TP of list?
    No another one friend
  2. #1817
    Feb 2021
    Hi all
    Kindly advise, apart from the six muratas, what else do I need to change on mine?
    Another one please. Will I be able to fit the original muratas? Is it enough room for one?
    Thanks a lot.
  3. #1818
    Jan 2019
    Somewhere between Continents
    Quote Originally Posted by maxxy View Post
    Hi all
    Thanks a lot.
    You should do the complete rework on your unit (this would be my advice to you)...
    About the murata filters "room", honestly i canīt tell you because i dont know the distance you have between pads...
    Just Consider helping Freely like I want to do...
    Thanks and Rep are Always Welcome...
  4. The Following User Says Thank You to boxsport For This Useful Post:
    maxxy (6th April, 2021)
  5. #1819
    Feb 2021
    It has 8GB class 10 SD card. Should I replace with Kingston 4GB class 4?
    Please also advise if the bellow two are any better. Does it need the complete rework?
    Thanks for your time answering.
  6. #1820
    Jan 2019
    Sd card should be good quality... even if it says calss 10, remember, that its China (they mark anything they want)
    Regarding the rework, you sould always consider to do it because its china stuff... you never know...
  7. The Following User Says Thank You to boxsport For This Useful Post:
    maxxy (9th April, 2021)
  8. #1821
    Jul 2016
    Denmark
    What do you guys rework your pcb with? Hot air to desolder or just solder iron?
  9. #1822
    Jan 2019
    Quote Originally Posted by sympho View Post
    i use hot air to desolder...
    some of them i use the hot air ro solder but other i use solder iron...
  10. The Following User Says Thank You to boxsport For This Useful Post:
    sympho (11th April, 2021)
  11. #1823
    Aug 2008
    i use same
    hot air to remove and iron to resolder mostly
  12. The Following 2 Users Say Thank You to tango For This Useful Post:
    boxsport (11th April, 2021), sympho (11th April, 2021)
  13. #1824
    Jun 2019
    today I received this same pcb. I don't think filters can be installed because there is no pad distance
    Post: maxxy
  14. #1825
    Jan 2021
    Hi all
    Thanks a lot.
    No, you definitly can not solder the murata filters on your pcb. Not without some "extensions" for the pads (i used some parts i took from a normal SD-card)
  15. #1826
    Aug 2008
    you can fit the murata filters on any pcb if you do it right
    i even posted a pic showing how
  16. #1827
    Jun 2019
    Where to buy led and sticker
    https://ibb.co/87MhVYR
    https://ibb.co/BsNfnt8
    Thanks for advance
  17. #1828
    Jan 2019
    Quote Originally Posted by jalami View Post
    Thanks for advance
    I also have 3D stickers and light-conducting tubes
  18. #1829
    Jun 2019
    Quote Originally Posted by tkmmazda View Post
    I'm interested . send me price for PM.?
  19. #1830
    Nov 2020
    Will Kess read ecu's more faster depending on laptop performance, cable quality, usb port type?
