Page 51 of 127 FirstFirst ... 41464748495051525354555661101 ... LastLast
Results 751 to 765 of 1896
  1. #751
    Mar 2016
    I reworked my kess, but now it wont read id or ecu content. Can somebody help?
    Parts list, all soldered under microscope, muratas ara grounded, no short cirquits.....
    Transistor, pnp, 45v, 0.5a, sot23, BC807-40,215
    1081222
    Diode, tvs, can, sot-23, PESD2CAN
    1510712
    ransistor, npn, bipolar, 50v, 100ma, 200mw, sot23
    BCR112E6327
    Transistor, digital, sot-23, PDTA144ET
    8736987
    Filter, cap, emi, 4700pf, 2a, 3 term, NFE61PT472C1H9L
    9528229
    Transistor, npn, 45v, sot-23, BC817,215
    1081223
    Cap, tant, 1uf, 35v, case a, T491A105K035AT
    1457411
    Cap, tant, 10uf, 16v, case a, T491A106K016AT
    1457414
    Cap, tant, 220uf, 10v, case d, T491D227K010AT
    1457505
  2. #752
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by SvenR1 View Post
    1081222
    1510712
    BCR112E6327
    8736987
    9528229
    1081223
    1457411
    1457414
    1457505
    post printscreen image here with what show you when yuo press info buton on ksuite
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  3. #753
    Mar 2016
    Hi thanks for reply, I found the problem one murata filter had cold solder joint (murphy law, it was k- line murata ) All okey now reads fast. Another problem is when I choos subaru denso ecu, no matter which one it sais invalid protocol file. Also some VAG ecus have same problem (Vag simos PCR2.1). I did sd card format, but nothing.
    Kess info:
    FW 4.036
    serial: K09021102
    customer code c0999
    group code c0999
    Software Im using is 2.13, I also have K tag and it works in same k-suite.
  4. #754
    If you have no problem with Vag simos PCR2.1 before you rework your kess, the problem is not the sw or sd files.
    Opel Astra G Y20DTH
  5. #755
    Mar 2016
    This problem was before rework also.
  6. #756
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Kess info:
    FW 4.036
    serial: K09021102
    customer code c0999
    group code c0999
    did you bought kess with this firmware from china store,or you updated your kess to this firmware...?
    outside forum:
  7. #757
    Jul 2016
    Any chance to find fw 3.099?
    it would be great.
  8. #758
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by zijad77 View Post
    it would be great.
    Why 3.099?
  9. The Following User Says Thank You to teerak2uk For This Useful Post:
    zijad77 (17th July, 2016)
  10. #759
    Jul 2016
    Quote Originally Posted by teerak2uk View Post
    Why 3.099?
    I had my kess v2 connected to internet and want to restore it, my Device is type M, FW 3.099
    Thanks for your replay.
  11. #760
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    sorry to jump in but lm looking for anyone that reworks ktag , can any DK Veterans pm me with details of anyone they know who does it , need rework and f/w update
  12. #761
    Mar 2016
    Quote Originally Posted by teamtuner View Post
    Hi, Yes I bought it with this firmware from china store.
  13. #762
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    as you must to know...this is full version kess...and work with 2.08 sw version...other shi+ version sw have thoses invalid protocols...
    other things mate...did china guys told you how you need to reset tokens into this firmware?...because is a little particulary situation for this fw
    outside forum:
  14. The Following User Says Thank You to teamtuner For This Useful Post:
    tigri007 (19th September, 2016)
  15. #763
    italy
    I'm looking for the original files for virtual readings of kess v2 .
    someone has them ?
    Folder : res / ori
  16. #764
    Mar 2016
    They did not mention how to reset, they said it have no limitation of tokens, this is the page where I bought it: http://www.aliexpress.com/item/DHL-F...08.0.83.duf3DK
    thanks,
    Sven
  17. #765
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    thanks,
    Sven
    will see after 30 write mod files...if is no limited
    outside forum:
