teamtuner (22nd July, 2016)
Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
there is no logic here mate
you bought a clone...reworked this clone...spended money...for only 30 writes?...........and you hope earn money for original tool....do you think that original will be unlimited?...NO...MUST TO PAY EVERYTHING THERE...even air...
and....YES...K-tag also is limited...need also tokens...
inside forum:ask me about...i will tell you all that i know
make me working for you...i will give you my paypal account
outside forum:
chiptuning,egr,dpf,add blue,dtc,Eu clones
gumacz100 (5th December, 2016)
ALL IS POSSIBLE in this worls...need only to want to do it...and also need to give help to the others if you want to be helped...so,first of all...use search buton,enjoy more time into our DK world,and be patience...i am sure that all your problems will have solution...
WHERE IS DK IS ALSO THE SOLUTION
outside forum:
kukukatsu (8th December, 2016)
Hello guys, i bought kess v2 with 4.036 firmware version, maybe you could say which software would be stable for this kess v2 clone? Some people of this forum said that only 2.08 or 2.12 works without any problem with this tool. I found 2.12,2.15, 2.21 and 2.23 software versions in CD... Chinese wrote that it don't have token limit, so it depends from your software version if there is token limits or not? I don't understand, thanks friends for your answers.
P.S PCB great qualitty with Murata filters, pcb 2016.3.2.
Look better for 2.08 greatings
Enviado desde mi GT-I9060C mediante Tapatalk
so token limits it depends from software or firmware version? Chinese declarate that them tool don't have token limit and in CD there is from 2.06 till 2.23 versions of software no matter which software and it doesn't have that limit or it's not true what chinese declarate?
chinese words are misleading people like yourself
no token limits doesnt mean that tokens are not needed it means you have to get tokens to reset the 30 writes you have in the tool
therefore after the 30 tokens run out then you have to reset them to another 30
read through the forum and the info is all here
good luck
