I can't see the transistors but the rest seems fine to me.
Hello i have installed sw 2.08 and good libraries to the sd, but now when i open ksuite every time it installs firmware again (without internet conexion), someone know the reason?
solved! i delete files on upgrade folder after upgrade it and now it doesn?t do it!
Is working for anybody Kess 4.036 clone with BMW E60 EDC16CP35 by OBD ? I have try many times to many E60 models, but no luck. I got KLINE and CAN, if I choose KLINE- get "wake up error", If I choose CAN, getting " Protocol not correct.Use protocol 164" ... where is problem ?
p.s. I have changed all components for KLine fixing even they were correct and good condition, nothing changed.
Tried with protocol 164 and selecting k-line?
What's wrong with this china clone ? This BMW with EDC16CP35 witch protocol should work, CAN or KLINE ?
Just finished reading this great thread - 6 bloody hours!!! Really everything is here, from rework instructions with parts list to links to good sellers. One thing seems to be missing though - towards beginning of the thread there were links to download internet safe 2.08 software and by now all these links are dead. Could someone re-upload it please?
PS by the way is that version really "internet safe"?
The only thing that's left to decide now is which FW to buy, 3.099, 4.024 or 4.036. I realise 4.036 differs from 2 others in token reset methods (harder to do, may require change of chip) so does it open enough new options to be worth it, compared with older ones? Any suggestions will be appreciated.
About E60, EDC16CP35 :Change speed to low. But is better to make this ECU on the bench. Is most safely!
Well, for sure my kess is not ok, today I tried to read a c4 2.0 hdi 136 dephi ecu, and i couldn?t kess said protocol error , I read a golf v bkd without problem but when i tried to flash it kess said error and ecu was bricked... I could rescued it with mpps v13
Same thing happend with other bkd before reworked and sew 2.24, with new eu components and 2.08 and new libraries for sd nothing changes...
maybe problem is for using windows 10? does someone know?
i don?t know what to do, i?m thinking to buy a galleto or other tool which works better.
Where new version Kess sw2.30 for Clone?
Changes?
Someone already tested?
WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
Fileservice
no thanks no pass
Will not work, all new protocols will be gray.
Hi I have 2 versions 4.036 one with trucks and another normal one. Yesterday I went to do a W205 MB with Ecu CRD3-651 I started reading but it gave 1 hour and 30 minutes of reading, has anyone tried it? I stopped him in the middle because he was not in my workshop.
regards
