nice PM mate...
Join DateApr 2015Posts3Thanks0Thanked 0 Times in 0 PostsDownloads0Uploads0
NO PM'S TO BE POSTED
nice PM mate...
8.23.motor (30th April, 2015), EcoTuningSolutions (30th April, 2015), muzikisme (20th December, 2015)
Below please find 4.024 firmware. CFG needed
Possible the other cfg to be linked to this one. Hwo has a spare nxp can try
8.23.motor (30th April, 2015), ankupis (16th December, 2015), apv (28th October, 2015), auto16 (16th June, 2015), charlietdi (27th May, 2015), cosmin cl (27th December, 2015), datapage (3rd May, 2015), florinyes (15th October, 2015), lvkas (20th June, 2024), Mazolla (7th November, 2015), Mulatre (30th August, 2015), samsung69 (3rd July, 2019), Sniperroyal (5th January, 2019), STEEVYAS (28th December, 2015), t1tan1 (30th April, 2015), titinou67 (3rd September, 2016)
no problem mate...i said...i am veteran of wars...bye...and good luck
What has that 4.024 in special? Is older than 4.036
As i said - is a 4.024 with crp3 disableled and full active all protocols. try it. i am out of changing nxp's - 16 nxp changed up to now![]()
So after 30 uses you can't reflash nxp with the firmware again as it's crp 3
No. Crp3 is direct from the begining. Just use the tool with the token provided. Come on are we tunners or........
I was searching inside 4.024 - look adress 007c010 - client code and 000200 serial number are the same.
We have also 2 types of tokens = cripted cfg.
The ones from video pack that is different from the working one. Who will test an update from 4.024 to 4.036.
This firmware posted 4.024 it has all protocols active boats etc.
someone must try to flash 4.024 in nxp and that to use update pack but just use the other cfg.- renamed from "bad token decripted we have to test with 4024" to "K10033818.cfg"
agstur (11th September, 2017), apv (21st July, 2016), auto16 (16th June, 2015), chiptorque (30th April, 2015), daxxer (26th April, 2016), florinyes (15th October, 2015), lev76 (19th January, 2016), lvkas (20th June, 2024), Mac Gyver (2nd August, 2015), mexanico1971 (2nd May, 2015), Mulatre (30th August, 2015), muzikisme (20th December, 2015), n_roy (21st March, 2019), Overtune (5th May, 2015), PETERALC506 (14th June, 2015), sarigol45 (10th November, 2015), t1tan1 (30th April, 2015), urcarpc (21st January, 2016)
i"m not finished all my tokens...but,i think is not need to reflash again the nxp...you don"t need to change the fw...i think you need to do again the same update from update folder with same cfg file...it will be rewrite the updates again...
ovi730 (30th April, 2015)
Hi Dan , indeed. I was asking to update from 4.024 to 4.036 not from 3.099 to 4.036
the firmware 4.024 havs all protocols activated.
MBTUN
please tell us the sequence of iap calls in order to cange the crp status and to be able to rerwite nxp.
ups no one want to test it ??????????????????????is your turn coleagues. thats why we are a comunity . please test and report!!!!!!!!!!!
Ok - one another thing to stimulate all of you.
Below KTAG FIRMWARE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Now start to comment on tnoter topic !!!!!!!!!! and please help for tests.
My question was after tokens expire can we reflash nxp with jlink or no
no no no no nxp reflash. you have to resset them. i have created the tool with the correct token. or use initial update pack.
all of you wants only tested tosutions. you have to work my friends. it is free now but put your contribution here or shut the ............off
