the heat-shrink sheath around the LED diode puts shivers.
Very bad quality
Very bad quality
Chip tuning professional.Winols original 4.30.File processing, DTC, DPF and EGR off.PCB Kess 5028, Ktag 8000.
Optimized SD Card files for any SD card CID
Cyrez (17th January, 2019)
it's china pcb, need to be rework
Is there a guide for diagnosing components of kess and ktag, like I found for UL46 chip for example, or we just must change all components randomly?
I ordered the first unit that you posted but from an ebay vendor.
http://blog.obdexpress.co.uk/2017/10...ed-pcb-rework/
I will post some pictures when it comes. Hopefully it won't take too long.
Could you post up a close-up picture of the left side of the board?
That will show the:
WF = Infineon, BCR112 NPN Digital Transistor
27E = ON Semiconductor NUP2105LT1G
6DW = NXP BC817,215 NPN Bipolar Transistor
A6c =MMUN2113LT1G / MMUN2113LT3G
K5B = BC807-25-7-F PNP Bipolar Transistor
Murata filter NFE61PT472C1H9L
I would like to know what the others think of these components. Chinese copies or legit?
If they are okay, the only difference that I can see is the substitution of BC817,215 for the original BC817,115. But it seems to have the same stats anyway.
Thx and good luck
edit: sorry, re-reading your post I think that you DIDN'T order the pcb with the different corners? The ad that is linked in my last post shows the original and modified corners pcb so it is a bit confusing.
I just want a picture of the modified pcb; that is the one that I ordered.
I will still post up a picture when it comes. I hope in about 2 weeks.
Rework info for ktag would be great
I am interested in doing this lads, if i rework my original slave kess v2 what exactly can i do with it, do i have to use clone software or can i still use the original software?
marvelg (23rd February, 2019)
Do you know anyone who sells the reworked version.
I am considering buying one.
Sent from my SM-G930F using Tapatalk
Ok thanks for that
