Page 96 of 127 FirstFirst ... 4686919293949596979899100101106 ... LastLast
Results 1,426 to 1,440 of 1894
  1. #1426
    heteromies
    Guest
    Quote Originally Posted by marvelg View Post
    Do you know anyone who sells the reworked version.
    I am considering buying one.
    Sent from my SM-G930F using Tapatalk
    And if need 5.028 version info, PM.
  2. #1427
    Member Jerak's Avatar
    Jan 2011
    Canada
    Quote Originally Posted by Cyrez View Post
    I think you will receive the same one, that i have received. My PCB has manufacturing date 01.04.2018 the "reworked" one with different Corners has Manufacturing date 01.04.2017. Nevertheless i am very interessted to see the Pictures of your pcb.
    So the ad said:
    - The left upper corner and the lower right corner notch size is not the same
    - WF = Infineon, BCR112 NPN Digital Transistor
    - 27E = ON Semiconductor NUP2105LT1G
    - 6DW = NXP BC817,215 NPN Bipolar Transistor
    - A6c =MMUN2113LT1G / MMUN2113LT3G
    - K5B = BC807-25-7-F PNP Bipolar Transistor
    - Using imported Japanese Murata filter NFE61PT472C1H9L
    I didn't get the PCB with the different corners but it is dated 2017.4.1.
    The components are WF, 27E, 6DW, A6c and K5B but I don't know if these are the actual ones stated in the ad.
    Anyone know if this is legit?
  3. #1428
    Dec 2017
    Quote Originally Posted by carmageddon View Post
    all china tools need to be reworked!
    Yes, throw them to the bin and buy legit tools! Who's going to develop them, the chinese? (no smilies here)
  4. #1429
    May 2018
    Reworked Clones or EU Clones are working good.
    Yes I know, you can't do the very newest cars. But you can read many many many cars via obd or with ktag on bench.
    Make money, save money and buy good original hardware.
    That's a good way and it works.
    Gesendet von meinem SNE-LX1 mit Tapatalk
  5. #1430
    May 2016
    Used kess v2 clone to remap 4 cars , so far no problems
  6. #1431
    Oct 2017
    Uruguay
    Hola James me podrias pasar la contraseņa y clave, gracias
  7. #1432
    Feb 2019
    You know when you've been going round and round in circles and you're not getting anywhere..... and your brain just seems to decide it's done for the day? That's how I feel at the moment; apologies if this is in the wrong place, you guys sound like you know enough to help;
    I'm not 100% sure what I have but it was sold as eu version with 5.017fw and red board but it's a green board and 4.036fw. It does have the no token magic but can't be connected to the internet. I did notice the cap (?) inside is rated at 25v not the usual 50v if that helps at all.
    I was using it happily enough as it was but I bought a Ktag that came with ksuite 2.23 that's apparently net safe and token free so I've been trying to get that to work so I won't need to worry about the internet with either. The Ktag works fine but kess says EEFFACE error or something like that.
    It seems to me that I need to update the firmware but other than that I'm none the wiser really and, like I said, my iq's gone down a fair bit since this morning
    Can anyone point me in the right direction please?
  8. #1433
    Mar 2016
    Default ktag rework
    someone can give their opinion, I have changed components, I have bought good quality, can someone say their opinion about my work?
  9. #1434
    Feb 2013
    UK Bristol
    Default does anyone know why this dongle is?
    My post helps you? Please Hit Buttons
  10. #1435
    joker01's Avatar
    Jan 2018
    guys I wanted to rework my green kb pcb ...... this list on the front page of the post is ok or are there other components to change ????
    thank you
    Transistors to use :
    BCR112
    MMUN2113
    BC817
    Murata filters:
    NFE61PT472C1H9L (connect ground for all of them)
    Capacitors:
    1uF - 35V
    220uF - 10V
    10uF - 16V tantalum
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  11. #1436
    Feb 2013
    UK Bristol
    Quote Originally Posted by joker01 View Post
    thank you
    BCR112
    MMUN2113
    BC817
    Murata filters:
    Connect MIDDLE PINS MURATTA FILTERS TO GROUND, not the signal
    Capacitors:
    1uF - 35V
    220uF - 10V
    10uF - 16V tantalum
    Go Follow Picture.
    I changed Voltage Stabilizators as well
    1 x LM1117 3.3v
    1 x PZT2907AT1G
    1 x LM2575s 5.0V
    all diodes SK14 (not required)
    Micro SD Card to better quality if is NO NAME (BLANK on the top) but very carefull, is not easy just copy CONTENT, need generate againb becase another card have diffrent CID so will doesn`t work, if you copy 1:1
  12. The Following 2 Users Say Thank You to pocinas For This Useful Post:
    joker01 (27th March, 2019), zalimhan74 (3rd April, 2024)
  13. #1437
    May 2018
    Quote Originally Posted by pocinas View Post
    I would like to know this too.
  14. #1438
    Aug 2018
    tranks
  15. #1439
    joker01's Avatar
    Jan 2018
    info guys ..... I tried to search fw kess 5.017 for nxp but I didn't find anything ..... could anyone share ????thank you,.....
  16. #1440
    May 2018
    Quote Originally Posted by elmer9 View Post
    tranks
    Look at this. You need and smd led to get this working.
    https://m.reichelt.de/lichtleiter-sm...cEALw_wcB&&r=1
  17. The Following User Says Thank You to Hexer84 For This Useful Post:
    elmer9 (1st April, 2019)
