guys, there is a resonator that looks like the same features, but with 0.07% tolerance instead of 1%,
surely it will be more precise .. someone tried it?
https://www.mouser.it/ProductDetail/...ZCctwg8A%3D%3D
compatible transistor instead of this code ???? BC817W115 ...... I ordered everything on mouser.it but these are not available ..... good alternatives ????
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
I took photos of users of this forum, I noticed differences, especially very frequently a "b4" component highlighted green,
also yellow color with different code,
when it comes to brown "ul46" component you can follow the link
https://www.mouser.it/ProductDetail/...SAAEgLCh_D_BwE
does anyone know these components? on purple PCB look original compared to red PCB clone
kess-rework2018.jpgthe "?" in the picture it should be, I'm not 100% sure
https://www.mouser.it/ProductDetail/...BRpDb%252B3w==
Those marked yellow make sense to change. Why are CAN drive.
Mainly in reading with Ktag by BDM. I may be partly right.
so the component is exact, I mean the 220 inductor?
I identified component b4 but there is a problem, in the original green PCB "SF Y5"
https://www.mouser.it/ProductDetail/...0UtT4Mxv8LOw==
instead purple PCB "SF E1"
https://www.mouser.it/ProductDetail/...f0YL1qSw%3D%3D
one corresponds to 39 v and one to 5.1v which to mount?
mounting E1 ???
https://eu.mouser.com/ProductDetail/...QCWzkdTw%3D%3D
please send an image of original kess v2 or purple PCB EU, where everything is read well
thank you
But this is obsolete. It is good to think of another similar.
This is a LV14 but do not think a reliable reference to it. Suggestions?
