I changed nothing. I am only intressting for 24V problem
You should change everything and test ... after this, you can come back and push the Thanks button.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
muzikisme (20th December, 2015)
I know mateI just hate when people that don't try anything but still they are in doubt if free solution is good.
genuine pcb no have any components on the backside
KESS 5.028/5.030 VR - KTAG 8.000 EU PCB
PCMFlash 1.2.0 dongle EU
STool/MTool v1.49 EU
ECU Flasher activation
betrescudan (21st May, 2015)
with replaced transistors as per my solution (genuine pcb), there is no need for any resistor on the back.
You are so wrong....
resistor is related to inner layer pcb circuits not component related
Exactly. Not all boards have that issue
Yes or no. Depending board's under layer issues...
Hi all
I did everything as it is in the Post and now my Kess is all gray.
Can help me please
ecutuners (4th June, 2015)
