I think I found the suppressor
https://www.mouser.it/ProductDetail/...SAAEgJDuPD_BwE
PCB green ori kees, PCB violet EU kess
link datasheet full
https://www.st.com/resource/en/datasheet/sm6t.pdf
press thanks if I helped you
I looking the code parts of U13 , U15 and U17.
Have problem.with kess " Connection estabilished"
I changed Nxp (thinking is broken) .. i changed FDTI and programmed with correct data. Still the same problem. U13
My post helps you? Please Hit Buttons
link datasheet full
pocinas (22nd April, 2019)
Computer detect KESS, after replacment FDTI yes i programmed (have another working 5.017 so i used MProg and saved DATA FDTI from working Unit, and programmed New replacment FDTI)
i do it test, solder working FDTI chip from working unit in this broken pcb and the same problem.. so..think is somwhere problem... NXP chip is works as well because soldered from working unit as well. What i see, i compared some resistans value, and see very low resistans on the one capacitor (this middle close FDTI chip and between SD SOCKET CARD) have 75 ohm when working unit 15k ohm...
i desoldered U13 because one of this signal going to U13 but resustance is still LOW, will measured circuit i try find element which made me low resistance
Thanks a lot, this little helps
Kess work.
Was 2 problems
1) Broken U17 74hct125 (after connect usb cable and wait couple second chip was warm and wormer) this is why was low reistance on this Capacitor, actually on the 5V line
2) Programmed content FTDI was wrong, strange because i take and save from working unit, (this working EPT i found on the internet from package 4.036)
Hayssam1 (9th June, 2023)
to empower the k-line change transistors and L9613,
to empower the can-line which integrated change?
Can you tell me which is the model with the red and green led that goes under the light guides? Can you also confirm me that the light guides are the right ones?
I tried this unit out with bootloader mode but couldn't find the protocol???
I need the EDC17 CP44 282 protocol that shows in the first page.
It doesn't show in the next page.
If I select the CP44 P268, I get wrong protocol with TOOL > ECU DATA.
I think that 1268 is for KTag.
This is KSuite 2.47, am I missing files?
Thank you.
Dont have now laptop in hand now to confirm this what i write below but
Tried with ksuite 2.32?
On the internet is 2 diffrent cracked 2.47 ksuite. One with all protocols shows (including grey which doesnt work anyway) and 2nd without grey means all this grey protocols is deleted, you can check example in BMW F series. If exist Fxx series they you will see model and all cars but protocols is grey and when you click.somw.cars will.have messagw Protocol cant find.... or another version ksuite.exe is when F series dont exist because dont work anyway so.
The diffrent is just ksuite.exe file..rest should be the same.
Okay, I got this figured out!
The KSuite pdf literature says that my ecu needs the 282 protocol, but at the top of the software it calls this the "Family".
Inside the software, instructions have a link to my hardware and there it also shows a 268 protocol. Easy to miss when you are not familiar with it.
I need Family 282, Protocol 268, which this software has.
I don't know why it would report wrong protocol.
Maybe you ecu was updated software and is latest or newer which was released after release 2.47 ksuite... so for support you ecu.need some kess supported 3.x ksuite.
Dont sure this, is just my suggestion
