Page 58 of 127 FirstFirst ... 848535455565758596061626368108 ... LastLast
Results 856 to 870 of 1896
  1. #856
    Jan 2017
    Quote Originally Posted by tango View Post
    you have to solder all middles to gnd
    so run a wire across all centres then from last 1 to any gnd point
    and for the holes yes just solder them
    Thank you very much tango for helping.
    So basically like in the picture? (yeah its ms paint)
    Or I am messing up grounds and should look for any GND on the PCB?
  2. #857
    Dec 2016
    Hi g00re,
    I don't think you want to solder a wire in the murata filters!
    He said that you need to solder the middle holes, they are located in the middle of the PCB.
    This is the original board (picture taken from the first post):
    https://postimg.cc/image/w00iwu9xh/
    As you can see, in the middle of the PCB the holes are filled with solder.
  3. The Following User Says Thank You to ankjay For This Useful Post:
    Ivan72petro (26th September, 2017)
  4. #858
    Aug 2008
    you have the idea right apart from dont connect them to any end of the filters otherwise thats then a short circuit
  5. #859
    Dec 2016
    tango,
    Sorry my n00bice but, is it necessary to solder a wire on the murata filters? :-|
  6. The Following User Says Thank You to ankjay For This Useful Post:
    smokinjoe (9th February, 2017)
  7. #860
    Aug 2008
    you need to make it something like this (making sure the centers are not connecting to outer ends anyway
  8. The Following 3 Users Say Thank You to tango For This Useful Post:
    ankjay (26th January, 2017), g00re (26th January, 2017), JarsaR (29th May, 2017)
  9. #861
    Aug 2008
    if your pcb is the 1 with no trace for them in centers yes its needed they are connected to gnd
  10. #862
    Dec 2016
    I'm waiting for my to arrive... It's the one from Bokins store, it should look like this:
    From what I see, they are connected, right? It's only necessary filling with solder the holes in the middle of the PCB. From what I see.
  11. #863
    Aug 2008
    you dont have to fill holes
    all you need to do with that pcb is check transistors are good etc
    no need for filters replacing or touching
  12. #864
    Dec 2010
    Checks the transistors. I think they are not correct
  13. #865
    Jan 2017
    Quote Originally Posted by ankjay View Post
    Thats the case, regarding your PCB murata`s, there is a place to solder centers for them, in my case there is not.
    @tango - I got the idea now. only thing is where do I find GND?
    This is how my PCB looked originally - http://imgur.com/a/CQH8f
    I have circled with red two GND`s I am able to find. Am I good to connect to them?
  14. #866
    Aug 2008
    if you look at the pic i edited of yours you will see where i made the gnd connection right at top
    scrape alittle green away then put a little solder then use that space
  15. The Following User Says Thank You to tango For This Useful Post:
  16. #867
    Jan 2017
    So thats how it works .
    Thank you very much!
    EDIT:
    While still on the topic, when soldering holes on KESS I think I messed up on this one - http://imgur.com/a/CGuQZ
    Circled with red, it looks like both connections are touching. Is this really bad? Can I live with it? I tried to clean it up but with not much success.
  17. #868
    Moderator
    PremierD's Avatar
    Jun 2009
    Oh dear ......what did you use an oxy acetyne cutter to solder with ? ....
  18. #869
    Jan 2017
    Quote Originally Posted by PremierD View Post
    Yeah, it looks quite bad , this was the result of trying to remove the solder and re-solder it afterwards, but I messed it up quite a bit.
    Im quite new in soldering, so...
    Thing is what can be done? whats the best way to clean this mess up? I assume this can create short
  19. #870
    Dec 2016
    Quote Originally Posted by g00re View Post
    Ok g00re, got it!
    You can do it using solder paste which will clean the solder area while touching the solder iron and isopropyl alcohol to clean.
    And lots of pacience!
    Quote Originally Posted by vasco fernandes View Post
    Do you believe that they aren't the correct ones? This pictures was an example, I've ordered it from the same store, so it should be the same.
    I really need to have the equipment in hand to see what I can do.
    Thanks!
