Hi all
Kindly advise, apart from the six muratas, what else do I need to change on mine?
Another one please. Will I be able to fit the original muratas? Is it enough room for one?
Thanks a lot.
Hi all
Thanks a lot.
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
maxxy (6th April, 2021)
It has 8GB class 10 SD card. Should I replace with Kingston 4GB class 4?
Please also advise if the bellow two are any better. Does it need the complete rework?
Thanks for your time answering.
maxxy (9th April, 2021)
What do you guys rework your pcb with? Hot air to desolder or just solder iron?
sympho (11th April, 2021)
i use same
hot air to remove and iron to resolder mostly
today I received this same pcb. I don't think filters can be installed because there is no pad distance
Post: maxxy
you can fit the murata filters on any pcb if you do it right
i even posted a pic showing how
Where to buy led and sticker
https://ibb.co/87MhVYR
https://ibb.co/BsNfnt8
Thanks for advance
Will Kess read ecu's more faster depending on laptop performance, cable quality, usb port type?
