Deleted post
Deleted post
3D stickers available again. Sticker "Alientech" and "K"
Post # 1524
Post # 1524
1pc Kess v2 reworked ready for work and for sale.
hello
I have soldered Crystal very smal 3.2mm lenghte it good?
CSTCE8M00G15L99R0 orginal 7.2 mm lenghte
Regards
boxsport (1st April, 2020)
To everybody that still has not managed to repair the K-line, I post my final transistor configuration that works perfectly, with transistor numbers included. If this helped someone click thanks
Hello
Kess v2 5017 red pcb online version
Reworked
Mercedes sprinter w906
Delphi crd3.20 Id read ok
Reading file : error while transferring data in reading. Not success
I have done software 2.47 and 2.53 not success, what it problem?
Iaw 4af all ok
Edc15p all ok
Edc16c39 all ok
Regards
I try also ktag not success
I find no on ktag crd 3.20 .
I try under delphi crd3.40
Not success
Help please
did any one have new software
Hey ! i try to read Siemens MS41 with Kess and no success , i have error " ERROR WHILE TRANSFERRING DATA IN READING" and even on bench connected ECU i have the same error :/ what should i do ? , this topic has so many sites i couldnt find anything
buenas tardes kess v 2.6 clon c puede actualizar a una versión más nueva si tiene la versión actualizada ayúdeme
Hi Guys,
i am currently toying with the idea to buy a Kess V2 EU Clone.
The Seller put this PCB in his auction:
https://ae01.alicdn.com/kf/HTB12OiLb...663524ff40ca71
and this Specs:
1.the left upper corner and the lower right corner notch size is not the same
2.Extra buzzer
3.WFs = Infineon, BCR112 NPN Digital Transistor
4.27E = ON Semiconductor NUP2105LT1G
5.6DW = NXP BC817,215 NPN Bipolar Transistor
6.A6c =MMUN2113LT1G / MMUN2113LT3G
7.K5B = BC807-25-7-F PNP Bipolar Transistor
8.Using imported Japanese Murata filter NFE61PT472C1H9L
should i give it a try or search for another one?
Greetings
boxsport (27th May, 2020)
Even if the board you get, comes with those components, you should ALLWAYS do the Rework to be sure the main components are OK...
Otherwise it will be a flip coin if it works good or not...
The one i bought came and it worked OK even when i didnt made the rework on it. and it seems to have the Originla components they claim...
But at the end i replaced them all just to be sure...
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
Zund (30th May, 2020)
