You can find ALL parts as per boxsport list if you just spend a few minutes looking for a compatible replacement.
Dont be lazy!
Dont be lazy!
Tryed with list from Boxsport, but they dont offer me parts that where similar to the one i Need, some parts which should be similar of voltage and so on had a bigger case and my should not fit on pcb.
i bought this at mouser and it should be usable for 2 reworks (about 27€ per rework):
Mouser-Nr. Part.Nr. Brand Description RoHS Pieces Price per unit Total 1 771-BC817W115 BC817W,115 Nexperia Bipolartransistoren - BJT TRANS GP TAPE-7 RoHS-konform 6 0,126 € 0,76 € 2 771-BC807-25W-T/R BC807-25W,115 Nexperia Bipolartransistoren - BJT TRANS GP TAPE-7 RoHS-konform 2 0,144 € 0,29 € 3 926-LM1117MPX3.3NOPB LM1117MPX-3.3/NOPB Texas Instruments LDO Spannungs-Regulator 800MA LDO LINEAR REG RoHS-konform 2 0,99 € 1,98 € 4 863-PZT2907AT1G PZT2907AT1G ON Semiconductor Bipolartransistoren - BJT 600mA 60V PNP RoHS-konform 2 0,324 € 0,65 € 5 833-SK14-TP SK14-TP Micro Commercial Components (MCC) Schottky Dioden & Gleichrichter 40V 1A RoHS-konform NRND 12 0,245 € 2,94 € 6 511-USBLC6-4SC6 USBLC6-4SC6 STMicroelectronics ESD-Entstörer/TVS-Dioden Low Cap ESD Protect RoHS-konform 8 0,432 € 3,46 € 7 581-TPSD227K010R0150 TPSD227K010R0150 AVX Tantalkondensatoren - fest für SMD 220UF 10V 7343-31 RoHS-konform 4 1,02 € 4,08 € 8 926-LM2575S-5.0/NOPB LM2575S-5.0/NOPB Texas Instruments Schaltspannungsregler 1A STEP-DOWN VLTG REG RoHS: Konform durch Ausnahmegenehmigung 2 3,13 € 6,26 € 9 994-MSS1260-224KLD MSS1260-224KLD Coilcraft Festinduktivitäten MSS1260 AEC-Q200 220 uH 10 % 1.42 A RoHS-konform 2 1,84 € 3,68 € 10 863-MUN2113T1G MUN2113T1G ON Semiconductor Bipolartransistoren - vorgespannt SS BR XSTR PNP 50V RoHS-konform 8 0,126 € 1,01 € 11 863-NUP2105LT1G NUP2105LT1G ON Semiconductor ESD-Entstörer/TVS-Dioden 27V CAN BUS Protection RoHS-konform 6 0,369 € 2,21 € 12 726-BCR112E6327 BCR 112 E6327 Infineon Bipolartransistoren - vorgespannt NPN Silicon Digital TRANSISTOR RoHS-konform End-of-Life-Produkt 10 0,159 € 1,59 € 13 81-PKM17EPPH4001-B0 PKM17EPPH4001-B0 Murata Audioanzeigen und Alarmsignale 72DB 4.00KHZ 17.0MM ALARM(R) RoHS-konform 2 0,972 € 1,94 € 14 511-L9613B-TR L9613B013TR STMicroelectronics Telekommunikationsschnittstellen-ICs Med Spd Data Intrfce RoHS-konform 2 1,33 € 2,66 € 15 581-TPSB105K035R2000 TPSB105K035R2000 AVX Tantalkondensatoren - fest für SMD 35V 1uF 10% 1210 ESR 2000mOhm RoHS-konform 4 0,522 € 2,09 € 16 667-EEE-FK1H221P EEE-FK1H221P Panasonic Alu-Elektrolytkondensatoren - SMD 220UF 50V FK SMD RoHS-konform 2 0,675 € 1,35 € 17 81-NFE61PT472C1H9L NFE61PT472C1H9L Murata Durchführungskondensatoren 4700PF 50V 2.0A EMI RoHS-konform 12 0,644 € 7,73 € 18 581-TRJB106K020R1000 TRJB106K020R1000 AVX Tantalkondensatoren - fest für SMD 20V 10uF 10% 1210 ESR= 1 Ohms RoHS-konform 16 0,59 € 9,44 € Total: 54,12 € Shipping cost: 0,00 €
The only part that i have to search now is: CSTCE8M00G15L99R0
Look at the datasheet - you can get others (from the same manufacturer even) that will be fine. My memory's terrible but the numbers mean things (theres a breakdown of what on datasheet)and it worked out that they didn't have CSTCE8M00G15L99R0 which was (plucking a number out of the air) max 15v but they did have one exactly the same spec but max 40v. Might not have been volts, could have been current or whatever but with a little bit of common sense you can find one that will work fine.
Mouser turned out to ship from u.s. though and, with postage, it came to roughly £40 in total to uk
Isn't that the resonator by the way? I asked my dad about it, he's worked in electronics for over 50 years and taught it at college and couldn't see any need to change it - so if you really can't find one, I maybe wouldn't worry about it
Cyrez (23rd September, 2019)
For a start, the R** at the end is just the packaging it comes in.
However, I did find this; 815-CR-8.00CELA-33-T
I didn't look for long though so there might be better, this says 6v dc max (I can't see a figure for the CSTCE8M00G15L99R0) but you'd do well to double check it doesn't get 12v when connected to the car before ordering.
Try this: https://www.mouser.co.uk/ProductDeta...PDljQmxA%3D%3D
everything looks the same to me except the height 0.7mm instead of 1.1mm but that might just be advances in manufacturing and materials I guess. Double check for yourself though.
What you're looking for, as far as I can tell;
8mhz ceramic resonator - surface mount
33uf
tolerance; 0.1% or less (frequency)
HxLxW = 1.1x3.2x1.3
I'm not convinced you need to worry much about it though, if the frequency and size are right and it's better quality than the original, I'd bet it'll be fine - if I'm honest though, I think I'd just leave that component rather than wasting much more time on it.
Cyrez (24th September, 2019)
I use:
81-CSTNE8M00GH5L000R
0,07%
Newer a problem
That's the one in my post above, great minds think alike!
hi guys, I saw that there are small differences between the components of the two lists
which are the best of the two?
Use this parts:
and also 1 Piece of: 81-CSTNE8M00GH5L000R
regards
Cyrez
adios15 (28th January, 2020), AlimK (17th January, 2024), blackcorri (5th January, 2023), boxsport (11th December, 2019), Burnsi (2nd January, 2020), Col19 (30th January, 2020), elmer9 (2nd December, 2019), fparmentier (10th November, 2019)
fg galleto v54 or kess v2 ?
