adios15 (28th January, 2020), Blood58870 (17th January, 2020), gas43 (23rd December, 2019), kapadokya (16th November, 2022), luizbregadioli (5th February, 2020)
hi everybody,
i did the reworked for my kess with the good components listed below, I did a picture for my kess which is a china kess but the last with some goods components, so I didn't change all , look at the picture I did.
I think it can help someone who want to do a rework.
I joined a picture with my kess after reworked.
Have a nice day !
no need to fill the welding holes, otherwise ok .. there is no stabilization for the 24 volt
change celestial highlighted components
bigbang63 (27th December, 2019)
ok thanks for this information !
Someone here sells Kess V2 already reworked? send private message
hi,
this is my shopping card for doing rework at my kess v2 china
because i dont want to pay 20€ for shipping, components are for 3 pcb´s.
maybe someone can take a look if this is ok or maybe i forgot something.
i will replace the cd card also, i have a new sandisk 32gb here. is this ok?
thx in advance.
Mouser-Nr. Herst.- Nr. Hersteller Beschreibung Stückzahl Preis (EUR) Gesamtpreis: (EUR) 511-L9613B-TR L9613B013TR STMicroelectronics Telekommunikationsschnittstellen-ICs Med Spd Data Intrfce 3 1,33 € 3,99 € 511-USBLC6-4SC6 USBLC6-4SC6 STMicroelectronics ESD-Entstörer/TVS-Dioden Low Cap ESD Protect 12 0,358 € 4,30 € 581-TPSB105K035R2000 TPSB105K035R2000 AVX Tantalkondensatoren - fest für SMD 35V 1uF 10% 1210 ESR 2000mOhm 6 0,531 € 3,19 € 581-TPSD227K010R0150 TPSD227K010R0150 AVX Tantalkondensatoren - fest für SMD 220UF 10V 7343-31 6 1,04 € 6,24 € 581-TRJB106K020R1000 TRJB106K020R1000 AVX Tantalkondensatoren - fest für SMD 20V 10uF 10% 1210 ESR= 1 Ohms 24 0,59 € 14,16 € 667-EEE-FK1H221P EEE-FK1H221P Panasonic Alu-Elektrolytkondensatoren - SMD 220UF 50V FK SMD 3 0,72 € 2,16 € 81-PKM17EPPH4001-B0 PKM17EPPH4001-B0 Murata Piezo-Summer und Audioanzeigen 72DB 4.00KHZ 17.0MM ALARM(R) 3 0,711 € 2,13 € 833-SK14-TP SK14-TP Micro Commercial Components (MCC) Schottky Dioden & Gleichrichter 40V 1A 18 0,245 € 4,41 € 863-NUP2105LT1G NUP2105LT1G ON Semiconductor ESD-Entstörer/TVS-Dioden 27V CAN BUS Protection 9 0,369 € 3,32 € 863-PZT2907AT1G PZT2907AT1G ON Semiconductor Bipolartransistoren - BJT 600mA 60V PNP 3 0,324 € 0,97 € 926-LM1117MPX3.3NOPB LM1117MPX-3.3/NOPB Texas Instruments LDO Spannungs-Regulator 800MA LDO LINEAR REG 3 0,99 € 2,97 € 926-LM2575S-5.0/NOPB LM2575S-5.0/NOPB Texas Instruments Schaltspannungsregler 1A STEP-DOWN VLTG REG 3 3,13 € 9,39 € 994-MSS1260-224KLD MSS1260-224KLD Coilcraft Festinduktivitäten MSS1260 AEC-Q200 220 uH 10 % 1.42 A 3 1,84 € 5,52 €
[QUOTE = elmer9; 3734949] Ho usato la configurazione nella tabella che alla fine sono gli stessi componenti della fotografia sopra, ma ho aggiunto altri componenti (17 per essere precisi) per una maggiore sicurezza, ora lo strumento è molto stabile, (Ho scritto unità di controllo sotto 12v)
per coloro che sono interessati ai componenti aggiuntivi allego foto (ho anche corretto il primo articolo, poiché il componente è stato sospeso)
grazie a tutti.
[Allega] 671.613 [/ attach] [/ QUOTE]
ciao, mandami il pass per il file rar, sto anche cercando di cambiare i componenti per il mio kess. Ho già cambiato tutti i componenti della lista, è migliorato molto, ma ho ancora qualche problema con Ford e Toyota. grazie
Cyrez (16th January, 2020)
Most of the tools from China are good to go nowadays. No need to change anything.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
kapadokya (12th November, 2022)
hello I can't find the photo pcb rework
