Torque Pro 1.8.49 MOD by masterlist (Android) whit plugins
Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Member rewalex's Avatar
    Aug 2013
    Mallorca, Spain
    26
    Default Torque Pro 1.8.49 MOD by masterlist (Android) whit plugins
    Torque Pro (OBD2)1.8.49 MOD
    plugins:
    Hyundai
    kia
    fiat
    MItsubishi
    nissan
    Reno
    no pass required
    I have more things for this app, if some one need widgets or need some .csv.Please write to me
    please rate this post if is helpful or Not .
    Best regards
    I'm not a pirate, I'm a starving seafarer
  2. The Following 43 Users Say Thank You to rewalex For This Useful Post:
    + Show/Hide list of the thanked
    Abel8906 (21st March, 2022),Alpinesport (5th June, 2015),angmar (15th May, 2016),asawin999 (18th January, 2019),atomatic (27th October, 2016),autoauto (12th February, 2022),bandit boy (29th April, 2015),banza (25th September, 2015),beongo (1st September, 2015),berilio (9th August, 2020),Col19 (6th November, 2019),enricogalati (27th April, 2022),hatimtai (13th June, 2015),hbalazs (3rd November, 2019),Jashmine1983 (7th June, 2015),jsg1200 (31st July, 2016),Kajoe (26th September, 2019),Krzysiek1997 (23rd April, 2022),LABA331 (8th April, 2022),masteralarm (6th May, 2018),maxen (11th March, 2020),mikelalu2 (23rd March, 2018),mikheas (2nd September, 2016),mimo232mimo (7th February, 2021),miticmladen (31st January, 2017),MMPSPORT (4th July, 2021),PaoloDigital (10th January, 2017),PowerCheck (24th April, 2022),pricardof (18th August, 2016),prippsbl (17th October, 2017),replay (29th April, 2015),Roy Suryadwiananda (25th June, 2016),saheta (2nd March, 2022),samyy (5th May, 2015),sax77 (29th September, 2015),shanny254 (10th August, 2019),Shokunin (11th January, 2017),sstop (10th June, 2017),teuton (8th June, 2015),tinchocbr (28th July, 2015),toledo2015 (5th January, 2016),trant (13th December, 2021),wepster1979 (28th December, 2018)
  3. #2
    Jul 2009
    18
    I use torque a lot it is very good is it possible that you have ford and vw plugins thanks very much
    Aug 2013
    Mallorca, Spain
    26
    ford some time have problems whit J1850-PWM protocol(whit Bluetooth adapters), if is not working ,You must to change the adapter.
    to work without problems whit protocol lISO-9141, ISO 14230 (KWP2000) ISO 9141 on BMW, OPEL, WV, AUDI, SKODA, VOLVOVAG you need COM 409.1
    Mazda ecu is similar if you are Lucky by work .
    must clean lvl Mazdaspeed whit LukyPatcher (ROOT requered)
    Racing Meter inside .rar
    [HIDE] ? Digital Gauges for RPM, Speed, Engine coolant temperature, Intake Air  temperature, Catalysts temperature, Engine Load, Turbo boost, Fuel  Consumption, Clock, Fuel pump and Rail pressures (gauge and relative  pressure).
    ? ****og Gauges with Auto Scale, Warning and fully  Customizable style, scale, angle, size and warning thresholds. For RPM,  Engine Load, Turbo boost, Engine coolant temperature, Intake Air  temperature, Speed, Catalyst temperatures, Fuel pump and Rail pressures.
    ? RPM LEDs Bar
    Customizable  colors, four styles and three animations available. Automatic or manual  threshold settings. Two additional LEDs Bar are available to display  Turbo, RPM or Load data.
    ? Gear Estimate
    This value is calculated with the speed and RPM values.
    ? Customisable dashboard & profiles
    Layout  your own dashboard. Move, rescale, add or remove any parameters, three  different layout profile can be saved and number of screens can be  increased up to five. Frame and LEDs style fully customizable.
    ? Shift Light
    Flash on screen, Automatic or manual threshold and color settings.
    ? Telemetry Viewer
    Display  Telemetry in real-time and save up to one hour of data. Two cursors can  be placed on the graph to measure the time between two points.
    The following data are recorded:
    Speed, RPM, Gear, Engine load, Turbo boost, Lateral forces, Longitudinal forces.
    ?  Import/Export the telemetry data as a CSV file on your sdcard for  further calculations. Export to RaceRender format supported with the  following data: Time, GPS Latitude, GPS Longitude, Speed, G-Forces, RPM,  Throttle position, Gear, Turbo.
    ? Heads up display / HUD mode for night time driving.
    ? G-Force Meter (plotted 5s)
    ? Acceleration measures
    Current and Best acceleration Widgets based on speed or distance. You can define the thresholds.
    Units available:
    Mph/Kmh ; ?C/?F ; psi/kPa/bar ; LPK/KPL/MPG [/HIDE]
  5. The Following 11 Users Say Thank You to rewalex For This Useful Post:
    autoauto (12th February, 2022),bandit boy (30th April, 2015),Col19 (6th November, 2019),hbalazs (3rd November, 2019),mikelalu2 (23rd March, 2018),miticmladen (31st January, 2017),s0L (10th October, 2018),saheta (2nd March, 2022),samyy (5th May, 2015),toledo2015 (5th January, 2016),trant (13th December, 2021)
  6. #4
    Aug 2013
    Mallorca, Spain
    26
  7. The Following 3 Users Say Thank You to rewalex For This Useful Post:
    acres09 (27th June, 2016),bandit boy (30th April, 2015),toledo2015 (5th January, 2016)
  8. #5
    Jul 2014
    Look Behind You
    Thanks also available on aptoide
  9. #6
    Feb 2016
    17
    have you got any csv files for subaru thanks
  10. #7
    Roy Suryadwiananda's Avatar
    Jul 2010
    Indonesia
    220
    Hello, i need for Toyota Hilux.apk , if you have please to share for us.
    Thanks .
  11. #8
    May 2013
    15
    Thanks!
    Regards
  12. The Following User Says Thank You to jsg1200 For This Useful Post:
    wehi123 (23rd October, 2016)
  13. #9
    Feb 2018
    Is this really working for ford?
  14. #10
    Feb 2010
    obd interfate is elm 327 (i think) and for ford specialy diesel is not working. for petrol is ok
  15. #11
    Oct 2019
    6
    Thanks man
  16. #12
    Nov 2019
    Nice mod just what i been looking for, appreciate it
  17. #13
    Feb 2021
    17
    thank you good sharing
  18. #14
    Jun 2021
    3
    thanks ......
  19. #15
    Jul 2021
    Zimbabwe
    Default -
    Whats the difference between "Free Value pack" and Pro version?I have just seen an announce into the free app to have value pack for 1,19 whereas Pro version is 5,99 Its for Android.
