File is ok
A friend came today with one octavia 1.9 bxe engine with a problem.The car working fine until you put the 5 speed on transmission then the car have black smoke limp mode and code p0299 boost pressure not reached.....He told me that someone did egr off.Can someone check the file?All connections (airtubes) are fine,turbo clean,maf replaced.
File is ok
IF YOU THINK IT'S EXPENCIVE TO HIRE A PROFESSIONAL,WAIT UNTIL YOU HIRE AN AMATEUR
kospoz (1st May, 2015)
hi, are you check boost pressure control valve n75 , n18,, and sometimes sensor G450 make this fault
Make a log with VCDS or Delphi for see turbo
I saw with vcds that the turbo pressure is ok the car goes into limp mode without hard acceleration.This car has a box with all connections n75,n18 all in one.Maybe this is the problem?With live data when the car is with limp mode the data of boost control shows 6%.
most of time if happens on 5th gear around 100-120 km/h
turbo is the problem
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
kospoz (2nd May, 2015)
IF you have boost control 6% your problem 100% in turbo.
What box ? Some tuning box ? Check wiring from ecu to Boost preasure sensor with light bulb.
VAG
