Results 1 to 5 of 5
    Jan 2011
    Default seat cordoba 07 key programming problem
    i have seat cordoba year 07 diesel trying to code a key i read on the forum sbb etc can do so i read the pin with sbb and its 192 i read it with with mvp its 19021 but its a 4 digit pin as far as i can see and its immo 1 also t300 is picking it up as 0912 cant figure whats going on if i try enter the pincodes i get access denied is there a wait time does anyone know
    Hampshire
    On most vag cars, whenever you get 19021 , ignor it . it is not pin code 100%. so by judging the others which are very simmilar, i take a guess and say they are also wrong pin nos, also check your dash lock time. you need a proper tool ,to pull the pin, or eeprom it.
    ps. leave ign on for 35 min, then try 0912.
  3. The Following User Says Thank You to nazz2 For This Useful Post:
    insomnia2009 (1st May, 2015)
    Jan 2011
    hi thanks for your reply were can i pull the pin from is it in the ecu
    Hampshire
    Most probably from the ecu,if you have MM cluster, you might have a MC9S12H256? whats the ecu no? if you put a good picture you should be able to read from the ecu,not sure on this model. whats the engine code?
    Jan 2011
    thanks again for reply the engine number is bnv
