Hi, I can help someone turn off the DPF in this car? I turned off the switch in the address 1CEE0C but the message is still the DPF filter. Wet filter.
2,0TDI 140hp VW Sharan edc16u31
Did you reset a filter?
So, it was this procedure.
I thought it was obviousECU EDC16U31
seba_m_ (9th May, 2015)
Did You reset DPF with diagnostic tool before You writed dpf off file?
work, thanks
I have the same problem, car runs but dpf light still on dash... maybe someone can have a look.... dump attached ecu is : 03G906016JP
any help with this please ???
