Results 1 to 5 of 5
    Default mbox home screen
    hope you can help.
    i have a mbox and its running android. when i turn on the box it has apps on the home page, online video, my apps,settings, xbmc, music, local, these app are all large and for easy access, under them there are some small app, my problem is iv gone from xbmc to kodi. kodi works so i removed the xbmc app, kodi isnt on the home screen so i have to go through folders to find it.
    so the question is can the apps on the home screen be moved if so how do i do it?
    i spent over a hour trying to figure this out using google with no luck.
    thanks in advance for looking
    can anyone help?
    Jul 2014
    Hi dont you go to the + and then you can add what apps you want to homepage so you find kodi and add it this way or is this no help?
  4. The Following User Says Thank You to pegasus53 For This Useful Post:
    darguewin (21st May, 2015)
    yes that puts it on the bottom that helped, but above that i have big app selection i wanted to put it as a large icon
    Senior Member shankill2012's Avatar
    ULSTER
    Press and hold on top of the app ( kodi for instance ) and you should be able to drag the app to a new screen where you can arrange the whole screen as you want it.
