yugo45 (14th February, 2017)
Green button would be more of a on/off button for cluster.
Pin 32 - 12v permanent
Pin 31 - 12v ignition on
Here you can make two switches like one red for power on and one green for ignition on.
I'm planing to get one similar like SVG 147 and 159 from supervag. it works good with vvd2.
If someone has please share the needle/test-point corespondent on the obd connector.
I'm interested about svg 149 cable too. It's possible Pogo pin is to gnd (obd 4, 5) connected? Someone has schematics or measured it?
Did you work out what the pogo pin is wired to ?
antotechaustin (3rd April, 2019), scotlock (4th July, 2018)
I have OBD plug and instrument cluster adapter/plug..... my question is how to rig it? I have color coded pinout for the OBD... but how to know which color wires from the cluster plug corresponds with which pins?.....or do I have to destroy the clip..just to see where each color wire is going to which pin?
ammreid (4th April, 2020)
Lads what would you do without me? You can buy ready made cables very cheap just go to this site: https://www.u-obd.com/
ammreid (4th April, 2020), crankycarl (15th June, 2020)
does it matter which way round the coil reader wires go guys ?
Tools owned.
AVDI commander.
Dashfixer orig.
Dashfixer clone.
Fiat km tool.
Opel km tool.
Ford KM tool.
Op--com colne.
Lexia & PP clone.
Smok PSA, volvo & ford
If someone helps you DONT FORGET TO SAY THANKS its only polite....
p1et (19th March, 2023)
