Results 1 to 15 of 17
    Top Poster Group MB Best's Avatar
    Nov 2012
    Default FGTech Galetto v54 problem writing EDC17
    hello
    i want to help me in this problem
    when i want to write flash
    when it up 4% it give me an error in writing
    my ecu it opel insignia EDC17CP19
    my picture is
    thanks in advance
    Must be cooperation between us
    Jun 2011
    Northamptonshire, UK
    Is your boot pin and extra resistors soldered ok.. I have used mine for this Ecu ok ...
    Nov 2012
    i solder boot in ecu ok not working
    are you writing back the flash from this ecu or from another?
    Fantomisback's Avatar
    Aug 2012
    i think he write another software number becouse of that he have problem in writing
    Nov 2012
    hello javyb
    i write it from boot mode tricore
    Apr 2013
    you dont understand ... what dump do you intend to write in ecu flash ? the original one or another ?
    Quote Originally Posted by Group MB Best View Post
    hello javyb
    Was u writing file back that you read from the ecu or file from another ecu
    Nov 2012
    sorry
    i intend to write original file in ecu another
    original ecu is damaged
    H.Wessel's Avatar
    sorry
    You can not do it in edc17, edc17 has OTP sector so forget about do it...
    Nov 2012
    Sure you want your words ? H.Wessel
    Jul 2012
    verification stable 12volt power and connections between bdm and ECU .. maybe some connection between bdm and ECU is not good
  13. #13
    Apr 2013
    what bdm my friend ? its edc17 bootmode tricore...
    if you want to swap ecu only immo off work with another one...
  14. #14
    Mar 2013
    otp sector not possible write again no way
  15. #15
    Apr 2013
    read flash from second ecu, make it immo off, start the car, job done...
