read by bdm, I can help.
Volta is no good!!!! Manual Solution.
other way not exist?
edit: i think possible turn off only in bdm read?
In bdm read it''s more easy.
thx for all helper, problem solved now ...
problem not solved, i try more files but after 3-4 weeks, regeneration turn on ...
not exist working solution for it?
Manual solution work perfect no regeneration ever again.
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
it work on obd read? or only on BDM?
Doesn't matter
Can OBD dump, no needed BDM, but only manual solution for it. Never try use "free" distributed tool.
here you are dpf_off
pass in pm
sanderman (4th June, 2016)
I've removed dpf and egr but my car, a mondeo 2000 tdci 103kw with sid 206, after some weeks start regeneration again. I've read this thread and also if it is one year old I wonder if in the end with the incumen file resolves the problem ?
Volta software is a crap, don't use it if you don't want to make a 'ghost car'
Post your dump and maybe someone will do dpf and egr off for you. You're a new member so wait patiently
