Results 1 to 3 of 3
    Oct 2013
    Unhappy CUMMINS ISM CM875 FAULT
    HI MATES
    NEED YOUR HELP I HAVE A 2004 INTERNATIONAL WITH FAULTS
    2348 AND 2384 ACTIVE
    WHAT APPROACH SHOULD I TAKE TO REMOVE FAULTS
    THANK FOR YOUR HELP
    MECHANIC007
    Roy Suryadwiananda's Avatar
    Jul 2010
    Indonesia
    Quote Originally Posted by Mechanic007 View Post
    HI MATES
    THANK FOR YOUR HELP
    2348 > EGR Valve Position Failed Automatic Calibration Procedure - Out of Calibration
    2384 > VGT Actuator - Voltage Below Normal or Shorted to Low Source
  3. The Following User Says Thank You to Roy Suryadwiananda For This Useful Post:
    mathura (3rd July, 2015)
    DK Veteran Poptest's Avatar
    Sep 2010
    I have fault 331 on ISM CN875. I suspect internal ECM failure on injector #1 circuit.
    Has anyone opened or repaired this ECM P/N 3103533......................... Thanks
