    kumbari's Avatar
    Germany
    Default Mazda 3 edc16C34 P1187 problem
    Hi all !
    I have one mazda 3 edc16C34 with P1187 ( on first turn ignition car is in limp mode .On second no problems) fault code. I remove dtc on flash
    , write again , no faults but car in fist time no power , limp mode. If i turn off and on again i have power and everythink is ok. This is the common problem on ford , mazda edc16c34 1.6 tdci .
    The only solution as i know from forums is to flash with vcm ids new calibration software but i Dosen't have VCM IDS.
    I flashed again the original file and fault code P1187 appear again on first time opening ignition , on second no faults.
    Can anyone help me ?
    For reference : https://euroesi.mazda.co.jp/esicont/...2c3835400.html
    Apr 2011
    Middle East
    Only calibration with VCM IDS
    Jul 2012
    Default p1187 off edc16c34 mazda
    attached file p1187 off,, my solution manual
    Fantomisback's Avatar
    Aug 2012
    Car is in limp mode erasing DTC will not reslove the problem
    Jul 2012
    it is true but eliminate dtc is a way to study the problem and to understand ..
    Many times the solution as in this case dtc off does not solve the problem, but this is becoming a way of working wrong ...
    you can do dtc off only in some cases ..
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Only reprograming IDS delete p1187
