Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
    murat332's Avatar
    Türkiye
    Default Bno 881 vwz1z7 code need
    Hi all friends
    FIS module could not be read
    serial number your friends can we code
    7 612 002 022
    bno881
    7L6 035 191 C
    VWZ1Z7D4168939
    Apr 2013
    RO-IS
    Hi is imposible try read after conect 12 V power on waith 1 min after read verifi conection!
  3. The Following 5 Users Say Thank You to kappa1 For This Useful Post:
    clydey (15th May, 2015), masterskay62 (15th May, 2015), murat332 (15th May, 2015), osman ?elebi (15th May, 2015), REZON (16th May, 2015)
    murat332's Avatar
    Türkiye
    My friend hooked 12v radio standby in case I'm trying to read up on the SD and the chassis hooked SCL pins.
    no hope for this radio.
    freewillover's Avatar
    LG N Africa
    Do you still have issue i will suggest something for you?
    There is nothing works like patience
  6. The Following User Says Thank You to freewillover For This Useful Post:
    murat332 (16th May, 2015)
    murat332's Avatar
    Türkiye
    radio and SCL pins are 4.5V in SD but not establish a connection between the programmer
    I could not read it.
  8. #6
    ilen's Avatar
    Feb 2013
    Serbia
    maybe help you..................?
    navi.rar
  9. The Following 2 Users Say Thank You to ilen For This Useful Post:
    murat332 (16th May, 2015), osman ?elebi (16th May, 2015)
  10. #7
    Apr 2013
    RO-IS
    Try this conection example for search SDA and SCL
  11. The Following 4 Users Say Thank You to kappa1 For This Useful Post:
    ilen (16th May, 2015), murat332 (16th May, 2015), osman ?elebi (16th May, 2015), REZON (16th May, 2015)
  12. #8
    ilen's Avatar
    Feb 2013
    Serbia
    I have me the same radio, now I read with UPA USB, like connect....
    bno.rar
    Regards....
  13. The Following 4 Users Say Thank You to ilen For This Useful Post:
    kappa1 (16th May, 2015), murat332 (16th May, 2015), osman ?elebi (16th May, 2015), REZON (16th May, 2015)
  14. #9
    murat332's Avatar
    Türkiye
    thanks friends
    Do not connect in the same way
    I understand went
    previously these types of radios were very hungry, but I think that there are problems FIS radio module defective
  15. The Following User Says Thank You to murat332 For This Useful Post:
  16. #10
    Bulgaria
    If you want you can try to repair!
  17. The Following 7 Users Say Thank You to bogege For This Useful Post:
    gamsahurd (11th January, 2021), ilen (16th May, 2015), kappa1 (16th May, 2015), MACKIE (7th October, 2016), murat332 (16th May, 2015), osman ?elebi (16th May, 2015), REZON (16th May, 2015)
  18. #11
    murat332's Avatar
    Türkiye
    Answering all here thanks to friends
    Monday test
    Thanks friends
    It was very good ideas
  19. The Following 3 Users Say Thank You to murat332 For This Useful Post:
    bogege (16th May, 2015), ilen (16th May, 2015), osman ?elebi (16th May, 2015)
  20. #12
    cubica1's Avatar
    Feb 2012
    Serbia
    did you try to low drop supply voltage for a couple volts?? and than connect??
    cuby
  21. The Following User Says Thank You to cubica1 For This Useful Post:
    murat332 (18th May, 2015)
  22. #13
    murat332's Avatar
    Türkiye
    hello my friend
    I will test today
    friends, thanks for your help
  23. The Following User Says Thank You to murat332 For This Useful Post:
    kappa1 (24th October, 2015)
  24. #14
    murat332's Avatar
    Türkiye
    3B0 035 191 D-VWZ1Z7-BNO881-FİS 24C32_Code
  25. #15
    Aug 2015
    code is 1498.
    wbr
  26. The Following 5 Users Say Thank You to Thinner For This Useful Post:
    golo (26th February, 2019), irfa (26th February, 2019), masterskay62 (26th February, 2019), murat332 (26th February, 2019), smoggy (26th February, 2019)
