Hello! Can you delete dtc P0489 in this SID202 file of a Ford 1.8 TDCI?
Thanks!
Thanks!
i can do this job for you without any problem
100% GOOD/TESTED/WORKING Solutions!! ,SwirlFlaps Off,EGR/DPF/NOX/DTC/Throttle Valve/ADBLUE/Lambda/Immo off,(Dyno)ChiptuningFiles,FileService,Remapping,Li censed Winols,
Give BDM read, it will easer to disable
here your dtc off
pass via PM
Yura123 (19th May, 2015)
