Page 11 of 13 FirstFirst ... 678910111213 LastLast
Results 151 to 165 of 192
Thread: XC MINI CONDOR
  1. #151
    lush29's Avatar
    Oct 2015
    i see is cutting to deep,all cutter,probe,clamp are 100% stable.
    yes both sides same.i will try to do an calibration but need an hon66 blade and dont have one, can i use other blade?
    want to make sure all is ok from the start,want to start again from zero just to learn how to use it properly.
  2. #152
    rob h's Avatar
    May 2011
    You can calibrate without a keyblade!
    To make sure, set machine to slowest moving speed.
    And cutter revs to max.
    Make sure the correct cutter is used, and choosen in the settings.
  3. The Following User Says Thank You to rob h For This Useful Post:
    daxxer (1st April, 2017)
  4. #153
    Feb 2013
    Dublin
    Hi Guys!
    Can Anyone tell me which is latest software version for XC Mini, please!?
  5. #154
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by pundravac View Post
    Hi Guys!
    depend of version you have
    http://forum.xhorse.pl/viewtopic.php...617146153268ad
  6. #155
    Dec 2015
    Quote Originally Posted by daxxer View Post
    Who need decoding orig HU64 key, post here good image of this orig blade....and i answer with code for Condor
    then you can choose only "cut by bitting" and the new blade type and press CUT...
    for me working: decoding through my eyes and go to direct cut by bitting...without read the orig blade in condor..
    God bless u daxxer my friend u r a smart guy
    NO ADVERTISING PLEASE
  7. The Following User Says Thank You to Nassreddine84 For This Useful Post:
  8. #156
    Feb 2014
    Quote Originally Posted by lush29 View Post
    Also check if the cutter has all it's teeth on. And remember to clean all metal shavings and dust so the machine can have good readings.
  9. The Following User Says Thank You to autoTkey For This Useful Post:
    lush29 (3rd April, 2017)
  10. #157
    lush29's Avatar
    Oct 2015
    Thanks for help. Today i will give another try. I let you know...
    Sent from my SM-G925F using Tapatalk
  11. #158
    Jun 2016
    Quote Originally Posted by rob h View Post
    Many have tried to reach Samic, true This forum, P.Ms, Skype etc.
    There does not seem to be any reasanable support.
    If there whas no D.K., we would not have any support at all!
    More then a month ago my Condor master failed me.
    The only bit off support, whas update software, which i allready used.
    Then i asked them, if i could buy a new touchscreen. And i have heard nothing since.
    So i have to say, Xhorse needs to do something.
    If Samic or Condorsupport is not capable ennough to advice on repairs, then attleast they should us sell parts.
    Providing us with parts catalogs, would be a good start!
    Samic is not in office for some days, I can't contact him neither, and was given another tech support skype: xxxxxxxxxxx Hope it helps.
  12. The Following User Says Thank You to crazylou2017 For This Useful Post:
    rob h (3rd April, 2017)
  13. #159
    siyadk's Avatar
    Dec 2012
    its holiday in china from april 2 nd till 5 th april
  14. #160
    lush29's Avatar
    Oct 2015
    Hi all, today dk was down in my side so i could not post anything,but anyway i did an w203 merc key spare, cut key with the same biting as original but still looks to deep cuted and not open the car. I will post pictures tmrw. I think is something from the calibrations...do no but really dont understand why. When decode the original and my copy both have same biting. But like i said looks to deep cut.
  15. #161
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    show all details and pictures
    as what HU64 type you decode-reading orig
    as what type you cut the new blade
    and others settings...
    many thanks to friend kevfield
  16. The Following User Says Thank You to daxxer For This Useful Post:
  17. #162
    lush29's Avatar
    Oct 2015
    Thanx daxxer, i will take picture from the beginning tmrw.
  18. #163
    May 2013
    Hi, had a similar problem and took a while to figure it out. Look on the other side of the key and you'll see that the little shoulder doesn't go as far up the blade as the original so it stops the key going deep enough in to the lock. I filed that back and all was good.
    Quote Originally Posted by cqae View Post
    was hoping someone can help me with Merc keys. Im using the big condor, I know this is the mini thread, but was hoping someone could help anyway.
    The last few Merc keys I have cut havent worked, have tried multiple times & read & re-read & calibrated too.
    attached is a pic of the key.....left is original, middle is a key I had cut by another machine & the right is the one from condor, I'm thinking its a blade problem?...does anyone know if there is an issue with the chinese blades?
  19. The Following User Says Thank You to Carkeysa For This Useful Post:
    daxxer (3rd April, 2017)
  20. #164
    lush29's Avatar
    Oct 2015
    Hi daxxer.
    Here is today pictures. Car is vw caddy hu66 selected car, then key decode,got the bitting then press cut new key and comes out like in the picture, when i decode the new key give me same bitting as old one but as you look on the picture key is cut wrong and i think to deep also.
  21. #165
    lush29's Avatar
    Oct 2015
    Hi daxxer.
