Page 7 of 13 FirstFirst ... 23456789101112 ... LastLast
Results 91 to 105 of 192
Thread: XC MINI CONDOR
  1. #91
    Apr 2015
    Quote Originally Posted by autoTkey View Post
    Is it available already ?
    yes,M3 clamp support ford FO21&citroen SX9 keys,is optional.contact your dealer get the sale info.
  2. The Following User Says Thank You to Samic For This Useful Post:
    tomasete (19th March, 2016)
  3. #92
    Mar 2010
    cantabria, north spain
    IMAG0578.jpgvolvo v40 key eats like 0.6 or more mm deeper than it should. it ate the clamp!!! and not very accurate
  4. #93
    Aug 2015
    Mars
    condor mini still having a some bugs.
    I just bought one month, and already update to latest firmware, v2.1.1
    1. as tomasete say, Volvo HU56 thickness setting wrongly, it should be 2.5mm, and cutting thickness should be 1mm.
    2. as tomasete say also, it will cut the clamp without notice. I have X6, will always notice that cutter will cut clamp when wrong setting, or something unnormal happen, but condor mini would not.
    3. I use Condor key data customize tool create my own key, after synchronize to condor mini, it have internal error 4.
    I try to delete but nothing happen, now i cant remove form condor.
    that all, no other issue anymore, mini condor very accurate and can create own key database for special key. This is very good function. Cutting speed also very good compare with X6.
    I very satisfied with mini condor.
    Hope mini condor can improve to better.
    IF I HELPED CLICK "THANKS"
    MVP pro,Tango, TMpro, SKP900, X100pro, i80pad, Mbtool, VVDI prog, KD900, Mini900, Ad900, Ts888, Ak500+, AK90, BMW Multitool, Xprog clone, miniprog, ETL, wellon vp380
  5. The Following User Says Thank You to haiz0708 For This Useful Post:
    tomasete (29th June, 2016)
  6. #94
    Feb 2013
    Dublin
    Hi guys,
    Just thinking to buy one of those Condor Mini machine,
    I have already Viper and Futura, just need one more for van.
    Just wish to ask you is it worth to buy this machine and how reliable is?
    Would like to know how its cut:
    VA2/VA6
    HU83
    Renault emg key
    NE73
    did some one cut SX9
  7. #95
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Va2 ok
    Va6 ok
    Hu92 ok
    Hu83 ok
    Sip22 ok
    Ne72/73 ok but some time need to adjust.
    with Tapatalk
  8. The Following 2 Users Say Thank You to didi_du_93000 For This Useful Post:
    Faraday (20th November, 2016), rm23 (2nd December, 2016)
  9. #96
    Feb 2013
    Dublin
    Can any one of you guys, who already have this machine advice me from where to buy this machine.
    I saw it on few web sites, but they have some differences. Look like to me, that is more than one manufacturer
    and price is different for few hundreds.
    Probably is not by the forum rules to put any seller link, so please send me a PM.
  10. #97
    Feb 2013
    Dublin
    Just one more thing, maybe I missed...
    can this machine cut Laguna/ Megane emg key?
  11. #98
    May 2010
    Europe
    As for MEgane emg key is better to make with manual machine.
    We have set the machine for:
    - Low speed
    - Thre time for cutting
    but with mercedes from 2000 spare mechanical key the condor make only two steps for the key. First way is normal, but the second way the machine works with very high force and with dificolty.
    Anybody have tested with this type of key?
  12. #99
    rob h's Avatar
    May 2011
    The slowest moving motion, is always good.
    But make sure that the cutter speed of a 2.5 mm is medium or high set.
    And the 1.5 mm always with the highest cutting speed,
  13. #100
    Mar 2009
    Hi, is there an application list anywhere ?
    Does it cut HU100R correctly ?
    Thanks.
  14. #101
    Sep 2015
    Hu 100 Opel tested and OK
  15. #102
    Mar 2009
    I was hoping for confirmation on BMW F series HU100R.
    Surprised there isnt an application list. Not gonna part with hard-earned until I see what it claims to do.
  16. #103
    Aug 2016
    Can mini condor duplicate key from smart fortwo 3 button? I see not have any smart in menu
  17. #104
    Nov 2009
    Greece
    No can't duplicate or copy by code smart 450
  18. The Following User Says Thank You to kleidaras For This Useful Post:
    MaxMin (6th January, 2017)
  19. #105
    rob h's Avatar
    May 2011
    Quote Originally Posted by kleidaras View Post
    Smart 450 uses YM23.
    Condor can make these 100%.
    Also hu100r works fine.
  20. The Following User Says Thank You to rob h For This Useful Post:
    madaxe (6th January, 2017)
