forget about eeprom if your car is starting...
just bad modifications in the flash
I have touran 2011 year with ecu edc17c46 after remap have MAF and FAP faults , read again ecu and i see eeprom now looks completely different flash don't have any changes write back original eeprom but again jumps everising back . Put original flash and eeprom no fault.
Anyone can help or just explain where is the problem.03L 907 309 R.zip
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
Anyone had before this problem ? And no need send to p.m messages " i can do for $" if don't have similar situation .
problem solved big thanks for user: ludbe
