Results 1 to 7 of 7
    Sep 2012
    turkey
    Default megane 2 df035 fault
    hi everyone
    ı have got megane sterling clon df035 fault
    can sameone help me
    amir_82013's Avatar
    Steering soft or Rigid ?
    Do you have Renault CAN CLIP Device ?
    Sep 2012
    turkey
    yes ı have clip
    car sterling is rigid
    but when ı erese tdc with clip it works
    amir_82013's Avatar
    check this process ...
  5. The Following User Says Thank You to amir_82013 For This Useful Post:
    ecufix (24th July, 2015)
    Sep 2012
    turkey
    have someone solition for this fault
    Sep 2012
    turkey
    ı change with used one power sterling but it not work
    ı clone old one 24c16 to used one then it start but give DF055 fault
    not give fault on dash in clip it s give df055 foult
    same one help me
    Sep 2012
    turkey
    ı change only sterling motor its work and no dtc
  9. The Following User Says Thank You to saitinam For This Useful Post:
    martinracing (29th September, 2020)
