Results 1 to 4 of 4
    garagetech's Avatar
    Oct 2008
    Default sprinter 906 2006 dpf help please
    hello can someone delete dpf from this file properly, sprinter came to me like this with half removed i believe
    diagnosed with mb star and coming up with dpf pressure sensor but no physical dpf present
    files are attached help appreciated
    thankyou
    Member Bm123's Avatar
    Feb 2015
    I have tested solution from the car if interested let me know
    100% GOOD/TESTED/WORKING Solutions!! ,SwirlFlaps Off,EGR/DPF/NOX/DTC/Throttle Valve/ADBLUE/Lambda/Immo off,(Dyno)ChiptuningFiles,FileService,Remapping,Li censed Winols,
    Hi.This is dpf off need to disconect temperature sensors and presure sensor.
    pass pm
    Clear inbox to send pass
  4. The Following User Says Thank You to nikka For This Useful Post:
    garagetech (20th May, 2015)
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by nikka View Post
    pass pm
    Thanks for the file it worked well but customer said he needs more power can you do something about this pal? I dont know the bhp on the file given but if you can increase by 20 or 30% please do he can pull better .
    Appreciate the work
