Best way mate remove fully Dpf or change the sensor
100% GOOD/TESTED/WORKING Solutions!! ,SwirlFlaps Off,EGR/DPF/NOX/DTC/Throttle Valve/ADBLUE/Lambda/Immo off,(Dyno)ChiptuningFiles,FileService,Remapping,Li censed Winols,
DPF is removed, no problem with that but only that sensor generate issue
If somebody can look and "adjust" my dump, maybe it was not cutt of right ?
thanks in advance
I can help you with full Dpf off and diff press sensor disconnected
P2456 cut, test and thank
