Siemens SID803A BDM connection for XPROG
Results 1 to 7 of 7
    omglol's Avatar
    Jan 2009
    Europe
    Default Siemens SID803A BDM connection for XPROG
    Hi!
    Does someone have connection diagram for SID803A? I need to read Motorola via BDM. Many thanks!
    omglol's Avatar
    Jan 2009
    Europe
    OK, I got the wiring diagram and I have read the ECU successfully.
    However, I get stuck at writing at 13%. Does anyone know why? Does anyone know if Piasini can write this ECU?
    Apr 2013
    Try to connect as
  4. The Following User Says Thank You to 2xded For This Useful Post:
    Zaveruha (31st July, 2015)
    Nov 2011
    EU
    Here you go.
  6. The Following 3 Users Say Thank You to bugarcek For This Useful Post:
    ecufix (20th October, 2016), nick_f (26th May, 2015), nikobg (16th April, 2017)
    omglol's Avatar
    Jan 2009
    Europe
    Thank you, I found that, as I said the reading process was successful. Now I am stuck at 13% when writing ...
  8. #6
    omglol's Avatar
    Jan 2009
    Europe
    Just in case someone faces the same problem ... you must erase external flash (just press "Erase"), then the programming will proceed without problems.
  9. #7
    Jun 2011
    Northamptonshire, UK
    Yeah you are right... I came up against the same situation but forgot that was what was the problem.. Also applies to Bosch, denso & visteon units when writing full dump...
