Thread: Help needed
    DK Veteran gibbo74's Avatar
    Nov 2008
    leigh lancs
    Default Help needed
    hi all help needed
    my netgear router has been playing up of late so ive been and bought a tp link 108m wr641g ,my isp is virgin and when i connect the new router it wont connect to the net can somebody please tell me what i need todo thanx in advance gibbo
    Sep 2008
    Quote Originally Posted by gibbo74 View Post
    hi all help needed
    when you say wont connect - do you mean it wont get an IP address for the ISP
    have you cloned you MAC address from the PC you are connected to the router admin page with, should be a button you press to do this. I always do this as I find the MAC address of the router never tends to work for me.
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    Red face
    hi all help needed
    Having done some reading on your new router it appears that it is just that, a router... You need a DSL modem router to connect to VM...
    TL-WR641G
    From what i read this kit is for adding to an exisiting network to give a wifi access point and not as the connection to the ISP. It appears on their wireless lan products page but not on their modem/router page, worst still they only seem to make ADSL kit which is for normal broadband, for cable broadband you need a DSL modem/router..
    Below is copied fromthe manual:
    Chapter 2. Connecting the Router
    2.1 System Requirements
    1. Broadband Internet Access Service (DSL/Cable/Ethernet)
    2. One DSL/Cable Modem that has an RJ45 connector (you do not need it if you connect the
    router to the Ethernet)
    3. Each PC in the LAN needs a working Ethernet Adapter and an Ethernet cable with RJ45
    connectors
    4. TCP/IP protocol must be installed on each PC
    5. Web browser, such as Microsoft Internet Explorer 5.0 or later, Netscape Navigator 6.0 or later
    You will note form Line 2 that you will need to attach a DSL/Cable Modem to this device to get it connected to the internet...
    Sorry for being the bearer of bad new mate,,, hope you have the receipt..
    Nov 2008
    leigh lancs
    i have got a virmin media modem which was conected to my netgear wifi router that broke that is why i bought my tp link wifi router to give me wifi via connection to my vermin media modem i can get the internet just cant get the tp link 2 give me wifi for some daft reason, i wasnt trying to connect dirct to the broadband connection im trying to connect via modem plus router
    Feb 2008
    In my Cave
    ok...
    wifi not connecting huh, same problem you had with the netgear i believe....?
    Nov 2008
    leigh lancs
    yes same problem but all will be sorted cos virmin have sent me a new router andthey are fitting it tomorrow so all will be sorted
    thanx
