a BIG HELP NEEDED PLEASE . this is 2011 sprinter 3.0L
my question is can i read it with bdm100? or galletto? or what tools / programmer do i need to read it? DK'S please help . thanks in advance
EDC 16CP31/36 on 3.0l obd galleto
FILE SERVICE
REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agricultureGenuine WinOLS user
If you remove the back cover the chance to damage the mcu are very high. Full BDM read/write is possible only if you cut a hole in the the aluminium cover above the bdm pin points if you want to swap the ecu .
do i need to use any adapters? with obd?
Galletto 2 read this ECU by obd
If U got the problem connect directly to ecu
Work 100%
MagPro 2 read it also
andrey (26th May, 2015)
If U need pinout
http://www.transpondery.com/pinout_guides.html
put supply voltage 14v after that try to indetify with edc16c31 .if is not work try with edc16c31/36 can
if not work enter in vito model 3.0 and try to identify
FILE SERVICE
pablobonome (29th May, 2015)
i already tried edc16c31 and edc16c31/36 can no success . it shows 13 volts as soon as i connecting to obd2
or do i still need to connect external ? .
will try vito
