Results 1 to 4 of 4
    Nov 2011
    EU
    Default Alfa romeo 166 2.4 jtd dtc remove
    Hello
    Can someone remove me a dtc from this bosch edc15c7:
    DTC is: P0191
    Fantomisback's Avatar
    Aug 2012
    beter to change sensor or repair something on rail pump dtc off not slove your problem
    regards
  3. The Following User Says Thank You to Fantomisback For This Useful Post:
    Tes1a (26th May, 2015)
    Nov 2011
    EU
    Rail pump is repaired, injectors are now from other fully working car, we also changed the rail pressure sensor and fuel regulator on the rail pump... What else should be?
    Aug 2012
    Then try it DTC OFF P0191 pass in pm
    regards
  6. The Following User Says Thank You to Fantomisback For This Useful Post:
    bugarcek (27th May, 2015)
