Results 1 to 15 of 22
    Dec 2010
    Default Problem with Injector Codes on MB W211 E350 08 BlueTec
    Did anybody encounter this problem before. We did attempt to chip tune a MB W211 E350 08
    BlueTec EDC16+ direct at the ECU with BDM. As usual we backup the whole ECU,
    modify the flash file, write it back and put the ECU back in the car, just like
    we have done many times before. Ignition on, no fans, glow plug light one,
    everythings cool, but then only about a sec run and the car dies. Tried a
    couple different mods, all the same, org BDM file back, same situation. Against
    my better knowledge we decide the ECU took a hit and needs to be replaced. Long
    story short, backup ECU with org BDM file in it does the same thing, 1 sec run
    and nothing. The Star gives us only 6 injector codes shorted to ground????
    2503-008, 2504-008, ..., 2508-008. Has anyone seen this before, Star has no
    further explanation? The only thing we found with those codes is something with
    a clogged injector return line, but customer wants to go direct to the dealer
    and they will go crazy on it
    MB E320CDI 07 Auto, 398891, Peter Winols.zip
    esepcially on sprinter most edc16 ecus get damaged if u open them to BDM. usually we cut a hole where the bdm pads are...like here
    http://carmasters.org/uploads/imgs/p...rinter_bdm.jpg
    Dec 2010
    ok, so if the ECU got damaged, why is the 2nd ECU doing the same thing, both ECU damaged the exact same way, I doubt it, did anyone see those German posts of those injector codes 2503-008 and so on for all 6 injectors? They are talking of a clogged injector fuel return line to the diesel fuel filter, same behavior, starts and dies?
    u did open both ecus?
    Dec 2010
    besides nice job on cutting that ECU, what did you use a can opener
    Dec 2010
    ahh yeah, how else could we play the backup bdm file in, we open them all the time, don't recall we killed one yet, really careful with the board ...
    Netherlands
    You probably have damaged the injector output stages.
    Specially when you take the board out of the ecu housing, look at the cooling pads of the power mosfets on the backside of the pcb, the are connected to the drain.
    So the heat conducting glue is also an insulator, replace the power Fets and take heatconducting isolation pads as was in the old Motronic ecu's.
    Had this once with a Volvo EDC16.
  8. The Following User Says Thank You to easytech For This Useful Post:
    speedtuningusa (1st June, 2015)
    Jan 2011
    Same thing happen me on sprinter it starts for 10 sec then die on both ecus your problem is you have killed both ecu damaged tracks on boards you need to cut a slot in ecu
    Sent from my GT-I9505 using Tapatalk
  10. #9
    i told him so...but he got ironic...so i gave up posting on thsi thread!
  11. #10
    Jun 2012
    wow, , never heard of cutting this ecu on this model, another good thread and the perils of opening ecu, that looks well dodgy cutting like that, but see the point to why has to be done like this, if prone to heat conducting and damaging board,
    Out of interest, what tool did they use ominimicu to open ?
    and how about after flash Glue it back or silicone to stop water dust etc ?
  12. #11
    usually a dremel or a radial saw. after that yeah just top off with silicone.
    on Sprinters edc16 always do like that for bdm. for remapp , dpf egr..etc obd read is enough!
    so if sprinters are delicate...so must be other model that share sam ecu on Mercedes....my thought..from my experience
  13. #12
    Jun 2012
    was going to say,,, surely obd poss on this ecu,
    trusty kess or Fgtech,
    Good info tho, lesson to others, Great forum, Great knowledge sharing,
  14. #13
    Dec 2010
    Quote Originally Posted by easytech View Post
    I guess its possible, but we must have done like 50 EDC16 ECU's like that and never had an issue, thats why its a little bit strange that it comes twice in a row???
  15. #14
    Dec 2010
    Quote Originally Posted by ominimicu View Post
    Relax big guy, it was just attampted humor
  16. #15
    Dec 2010
    opened another 2 Sprinter EDC16+ ECU's, cloned them without problems, living on the edge i presume haha
