Page 261 of 295 FirstFirst ... 161211251256257258259260261262263264265266271 ... LastLast
Results 3,901 to 3,915 of 4423
Thread: VVDI PROG
  1. #3901
    ASCM's Avatar
    Oct 2018
    Yes its third generation as of 2018
    Sent from my SM-A125F using Tapatalk
  2. #3902
    Dec 2010
    Quote Originally Posted by shgatev View Post
    Hello, I am trying to clone this BCM of Ford Fiesta 2020, I read the old Renesas vh-850 with VVDI, all was ok, made backup to the new one files and wrote the c-flash, but when tried to write d-flash there is error, no way to write it. There is an error on erasing or at writing start. MCU is R7F701053, Now, can read only ID and Security bit, I dont know whats wrong help or suggestions are welcome, thanks.
    I also failed several times via vvdi, only FDRS online programming succeeded
  3. #3903
    Supas's Avatar
    Jun 2020
    Will someday add Micronas to read? Or is it going to be impossible due to the hardware limitation of the VVDI PROG?
  4. #3904
    Aug 2015
    Quote Originally Posted by waldi View Post
    Yes, but now I have two dead bcm, I tried to change CPUs but doesnt worked, now have two dead BCMs, and if I buy new second hand one without working key will be able to do it online?
  5. #3905
    Sep 2010
    Brasil
    My firmware had a problem. Someone would have a solution. Please?
  6. #3906
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Sucuri View Post
    The security chip in your vvdiprog called DALLAS is only storing the secu data when power is present. If it's lost then the DALLAS is going empty and your prog flip to "unsecured state" and no more working. Thats why a big backup battery soldered on your prog pcb. If your backup battery is depleted or faulty OR thats the main reason:
    When you plug the usb port and the power comsumption is little bit bigger (like you attached some adpter to the vvdiprog too) or the backup battery is aging, or your laptop usb is not working very well...etc If this conditions are met the the power is lost (even is just milliseconds) and the Dallas is going empty.
    The only solution when you asking your reseller to refurbish your prog. Bcose it's the very basic security programming stuff they have to send back your prommer to china.
    Unfortunetly it's a very common problem in the automotive diag/etc industry. (cgdi, vvidi, smok..etc) For me the whole concept is inexplicable. They know the DALLAS need continous power and they are know the backup batterys are going bad sometimes, this simple led to extra work, time, shipping and bad reputation especially when far more better security solutions are available.
  7. The Following 2 Users Say Thank You to jodge For This Useful Post:
    ProblemChild (5th November, 2023), taxo1965 (18th January, 2022)
  8. #3907
    s qubiak's Avatar
    Jun 2017
    Polska
    Bosch
    VW Radio LOW EU UP2 BXV
    1K0 035 186 AN
    815 7 640 211 360
    Made in Portugal
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
  9. The Following 6 Users Say Thank You to s qubiak For This Useful Post:
    danielif (15th January, 2022), dawidhubert (21st January, 2022), ecuauto (17th January, 2022), hivrich (15th January, 2022), rafal (15th January, 2022), spacer73 (16th January, 2022)
  10. #3908
    s qubiak's Avatar
    Jun 2017
    Polska
    RCD 310 .
    Connect external 12V
    Radio OFF.
  11. The Following 9 Users Say Thank You to s qubiak For This Useful Post:
    bersch8688 (16th January, 2022), danielif (15th January, 2022), dawidhubert (21st January, 2022), hivrich (15th January, 2022), miroopel (15th January, 2022), rafal (15th January, 2022), spacer73 (16th January, 2022), ttzag (13th February, 2022), vas100 (15th January, 2022)
  12. #3909
    Dec 2010
    Yes, via fdrs online as you have access and hardware and bcm with the same part numbers
  13. #3910
    Maartinj's Avatar
    Nov 2010
    v5.1.1 (2022-01-24)
    * This version DON't need update firmware
    >>>DOWNLOAD<<<
    * Modify LOCK_BCM2-1(ADAPTER), LOCK_BCM2-1(WELD),LOCK_BCM2-2(ADAPTER),LOCK_BCM2-2(WELD), options in <4-IMMOBILIZER>-><AUDI>:Optimize the process
    * Fix DSM(2M25J/3M25J) diagram in<8-OTHER>-><BENZ>
    * Add <9-TEST>-><TEST_FUNCTION>
    + Add MB91F522, MB91F523, MB91F524, MB91F525, MB91F526,
    MB91F725, MB91F775, MB91F777,options in<2-MCU>-><FUJITSU-MB9XF>
    + Add TC21X-8F(JTAG), TC22X-12F(JTAG), TC22X-16F(JTAG), TC23X-16F(JTAG),
    TC23X-24F(JTAG), TC23X-32F(JTAG), options in <2-MCU>-><INFINEON-TC2XXX>
    + Add XC2336A-72(JTAG), XC2336B-40(JTAG), options in <2-MCU>-><INFINEON-XC2XXXX>
    + Add SPC560P34, SPC560P40 options in <2-MCU>-><ST-SPC560XXXX>
    + Add JIEFANG J6(R7F701441) option in <5-DASHBOARD>-><FAW>
    + Add INSIGNIA AIRBAG(SPC56AP54) option in <7-AIRBAG>-><Opel>
    + Add BYD G3 ESL option in <8-OTHER>-><BYD>
    + Add CT6 option in <8-OTHER>-><CADILLAC>
    + Add X.E.N.I.A S80 BCM(SPC5602BXLQ) option in <8-OTHER>-><FAW>
  14. The Following 13 Users Say Thank You to Maartinj For This Useful Post:
    amaflo (25th January, 2022), brodaty (26th January, 2022), dawidhubert (27th January, 2022), KADE007 (24th January, 2022), lion0304 (26th January, 2022), PremierD (9th February, 2022), s qubiak (24th January, 2022), Stelaras26 (24th January, 2022), Supas (24th January, 2022), taxo1965 (25th January, 2022), trinicolin (26th January, 2022), vas100 (25th January, 2022), weza247 (24th January, 2022)
  15. #3911
    ASCM's Avatar
    Oct 2018
    Did you added any option to read opel bcm nec
  16. #3912
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    NEC is locked on Opel BCM. You need to read via obd then write back via jtag
  17. The Following 4 Users Say Thank You to lupu_sandu For This Useful Post:
    miroopel (27th January, 2022), PremierD (27th January, 2022), taxo1965 (29th January, 2022), weza247 (1st February, 2022)
  18. #3913
    ttzag's Avatar
    digital-kaos
    hello guys
    bmw x1 2010 frm 3 repair
    -select the prtition size EEE to 0 Dflash 128
    read Dflash then save
    extract eep from D
    write eep partition 16 sector and Dflash 0
    open eeprom and write
    when i write its ask me another time to select partition manually ... select yes but write error
    any suggestion please ?
    i repaired many frm by this way before
    [2022-02-07 10:15:32] : Try Frequency success
    [2022-02-07 10:15:32] : ID 2M25J 0XC482/3M25J 0XC482
    [2022-02-07 10:15:32] : Start communication...
    [2022-02-07 10:15:32] : D-FLASH: 65535 Sectors ( 16383.75 K ) EEE: 65535 Sectors ( 16383.75 K )
    [2022-02-07 10:15:33] : User select yes
    [2022-02-07 10:15:38] : Write length:0x1000
    [2022-02-07 10:15:38] : PartitionD-FLASH: 0 Sectors ( 0 K ) EEE: 16 Sectors ( 4 K )
    [2022-02-07 10:15:38] : Writting...(0%)
    [2022-02-07 10:15:38] : Write Error
    read
    Actions speak louder than words
  19. #3914
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by ttzag View Post
    hello guys
    extract eep from D
    read
    Did you try like this
    http://blog.vvdishop.com/repair-bmw-...ith-vvdi-prog/
  20. The Following User Says Thank You to teerak2uk For This Useful Post:
    ttzag (7th February, 2022)
  21. #3915
    ttzag's Avatar
    digital-kaos
    Yes i tried
    Solved by write eep with last version of vvdi prog
    Thank you
  22. The Following User Says Thank You to ttzag For This Useful Post:
    teerak2uk (7th February, 2022)
