Page 10 of 295 FirstFirst ... 567891011121314152060110 ... LastLast
Results 136 to 150 of 4422
Thread: VVDI PROG
  1. #136
    Apr 2015
    Quote Originally Posted by CryptoKey View Post
    found in all the versions, always the same. NOT ID-0000
    MCU - 9S12DG256 also beaten.
    this does not work!!!, nor welding, nor versions, all checked ..here the technical VVDI-PROG he stayed asleep.
    mate,get ID 0000 or FFFF means haven't communication with the chip.please check the connection of chip.
    and if you have other Motorola chip,please try to check whether can read.
  2. #137
    Oct 2015
    has anyone had issues with this killing cas4?
    I guess I am not so scared, since I can program a new one with autologic, but I am consider getting this to use with vvdi2. Cheers
  3. #138
    gopelhu's Avatar
    EU
    HI Samic.
    CAS2 with 2K79X, there are two versions one can not read.
    ID-2K79x not recognize possible that another pinout, R270 says "NOT 5v Power" with the same connection that standard version of the image.
    - You could look and reprar this ruling.
    CAS2 I have this test,
    Attachment 336543
    Hi all,
    If it is 2K79X Motorola 9S12DG256 then pls connect the 5V to XIRQ pins. If 112pins then 56pin and if 80pins then 40pin.
    Connection 112pin:
    +5V 56pin
    GND 14pin
    BKGD 23pin
    Reset 42pin
    RXD0 89pin
    TXD0 90pin
    Connection 80pins:
    +5V 40pin
    GND 10pin
    BKGD 15pin
    Reset 30pin
    RXD0 63pin
    TXD0 64pin
    Pls let me know this solution works or not.
    Regards,G
  4. The Following 3 Users Say Thank You to gopelhu For This Useful Post:
    boxsport (21st December, 2019), CryptoKey (28th October, 2015), lidons (28th October, 2015)
  5. #139
    Apr 2015
    Quote Originally Posted by gopelhu View Post
    Hi all,
    Connection 112pin:
    +5V 56pin
    GND 14pin
    BKGD 23pin
    Reset 42pin
    RXD0 89pin
    TXD0 90pin
    Connection 80pins:
    +5V 40pin
    GND 10pin
    BKGD 15pin
    Reset 30pin
    RXD0 63pin
    TXD0 64pin
    Regards,G
    mate,from your connection line is not right.you can refer to the standard connection diagram as follow:
    this connection diagram will add to next version
  6. The Following 5 Users Say Thank You to Samic For This Useful Post:
    CryptoKey (28th October, 2015), DashProg (28th October, 2015), garagetech (28th October, 2015), gopelhu (28th October, 2015), Maartinj (28th October, 2015)
  7. #140
    CryptoKey's Avatar
    Jul 2015
    Europe
    I am left with the customer, for tomorrow afternoon or Friday afternoon.
    @Samic @gopelhu .. Have to raise both legs MCU? It is very similar to Xprog, is it possible?
    @ Samic, This MCU is securely. the jump is the VVDI?
  8. #141
    gopelhu's Avatar
    EU
    Quote Originally Posted by Samic View Post
    Hi bro,
    My pinouts as the normal programmer ( Like upa or xprog...etc ). VDDX2 equal to the XIRQ pins.
    The renault megane has uses as the same processor 9S12DG256 and other cars, but I read all 9S12DG256 processors with my pinouts....
    Regards,G
  9. The Following 4 Users Say Thank You to gopelhu For This Useful Post:
    antonypaul (23rd August, 2016), boxsport (21st December, 2019), cjawahir (31st October, 2015), Siham (28th October, 2015)
  10. #142
    Apr 2015
    Hi bro,
    My pinouts as the normal programmer ( Like upa or xprog...etc ). VSSX2 equal to the XIRQ pins.
    Regards,G
    Yes,maybe this type can use XIRQ as the VSSX2,get the chips data.but the standard power supply pin is the VSSX2 of processor 9S12DG256.
    you can see this follow photos,the last one is the Recommended PCB Layout for 112LQFP Colpitts Oscillator
  11. The Following User Says Thank You to Samic For This Useful Post:
    gopelhu (29th October, 2015)
  12. #143
    gopelhu's Avatar
    EU
    If the 2K79X has the CAS module, then 100% securely.
    I wrote one wrong thing. Not a VSSX2 but VDDX2 equal with the XIRQ pins. Sorry again....
    Regards,G
  13. #144
    Apr 2015
    VVDI PROG The Latest V3.9.2 version update
    v3.9.2 (2015-10-30)
    * This version DON't need update firmware
    + Add CAS2 Version2 connection diagram
    + Add PCF79XX connection diagram
    + Add MC9S12XEQ384,MC9S12XEG384, MC9S12XES384 options in <2-MCU>--><Motorola>Mask (2M25J,3M25J,0M12S,1M12S)
    + Add MC9S12XEP768 options in <2-MCU>--><Motorola>Mask (4M48H,5M48H,0N35H,1N35H)
    + Add MC68HC05X32,MC68HC705X32 series Mask (0D62J,1H52A,0D69J,1D69J,2D69J) (need the MC68HC05X adapter)
    * Fix MC9S12XE series ID read problem
    * Fix MC9S12XE series EEE write problem
    * Change Audi J518 connection diagram
    Notes:1. 3.9.2 version software include PCF79xx connection diagram show parts as above.
    2.copy this link to google chrome/firefox bowers and download.
  14. The Following 5 Users Say Thank You to Samic For This Useful Post:
    CryptoKey (30th October, 2015), DashProg (31st October, 2015), garagetech (31st October, 2015), gopelhu (31st October, 2015), Maartinj (31st October, 2015)
  15. #145
    CryptoKey's Avatar
    Jul 2015
    Europe
    I could not read the MCU, in any way, VVDI-prog indicated ID0000 in V3.9.1, rosfar said "pinned error" with xprog have not tried to read. think it must be some erro of identificancion MCU, try to get one of segundamano to leave doubts and do the tests.
    VFDI did not read flash EEP or by OBD2
    In the end I managed to add key directly from CAS2 connector with cables DB29 of FVDI.de this way all Ok.
    indicated that this CAS2 or there is a problem or I had something exceptional with this, clarification would not be a bad error.
    greetings and thanks to all, I hope you assist you very soon.
  16. The Following User Says Thank You to CryptoKey For This Useful Post:
  17. #146
    Jan 2011
    whats your fews on this programmer how about 9s12 with mask 1l15y anyone try and does anybody recommend i have vvdi 2 so far mixed results
  18. #147
    garagetech's Avatar
    Oct 2008
    Where do we get this pcf79 adaptor from ?
  19. #148
    Quote Originally Posted by garagetech View Post
    The pcf79xx are locked and I doubt this unlocks them - it would be amazing if it can read a locked pcf
    This will more likely be copied from orange 5, so it will erase write and read (once erased/unlocked)
  20. #149
    Oct 2015
    Soviet Union - USSR
    HI. when rosfar ask: "do you check pin test?" you click YES or NO? when I try read cas2 with 2K79X, I have some error to. When rosfar say "do you check pin test - I click "NO" and read is succesfuly. I do this 2 times in 2 cas2. when I clicked "NO", I was afraid to lose the dump.
  21. The Following User Says Thank You to exSPEEDyTOR For This Useful Post:
    CryptoKey (1st November, 2015)
  22. #150
    Oct 2015
    Soviet Union - USSR
    v3.9.2 (2015-10-30)
    Samic Hi!) can I use this adapter from X-prog in VVDI to read MC68HC05X? Thanks2015-10-31 16-03-35.JPG2015-10-31 16-03-51.JPG
  23. The Following User Says Thank You to exSPEEDyTOR For This Useful Post:
    Jobeso66 (27th August, 2019)
