Page 101 of 290 FirstFirst ... 519196979899100101102103104105106111151201 ... LastLast
Results 1,501 to 1,515 of 4348
Thread: VVDI PROG
  1. #1501
    May 2013
    VVDI2 is very limited in remote production but works with Chinese regional remotes. I don't understand the need for different remotes for different regions. I have a VVDI Key Tool bought here in South Africa but remotes I import from China don't work on it. I think that's why Keydiy will remain the front runner in the Remote supply business as you buy their remotes and they work in any region. By trying to protect their distributors they actually limit their sales as there are other tools that do the same job with a better selection of remotes without regional restrictions. I am a big fan of Xhorse products and also have VVDI2, VVDI MB as well as VVDI Prog so just pointing out where I think their failing their customers.
    Last edited by Carkeysa; 4th October, 2017 at 07:55 AM. Reason: Put on the wrong group but still relevant here.
  2. The Following 3 Users Say Thank You to Carkeysa For This Useful Post:
    obeids (5th October, 2017), sniegavirs (4th October, 2017), strikeforce2 (16th February, 2019)
  3. #1502
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Quote Originally Posted by Carkeysa View Post
    Yes ... Their failing their customers. ..
    They do not even bother to make remotes in VVDI2 in English
  4. #1503
    ttzag's Avatar
    digital-kaos
    1-sonata 2005 2006 failed to read .
    I reflashed my cable to ver 3 but can't connect to mcu ,when I put 12 v power to ecu as shown in the document pc can't connect to vvdi prog. when I remove 12 v, pc connect but can't read .
    2- Bosch me 744 can't read .
    is there something wrong with the cable ?
    Sent from my SM-A520F using Tapatalk
    Actions speak louder than words
  5. #1504
    ttzag's Avatar
    digital-kaos
    mg7.9.8 can't read.
    I checked wiring twice
  6. #1505
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Its just my pc not loading mega.co.za ?
    Tried to download vvdi 4.6.0 6.1 throwing error. On.all downloads
  7. #1506
    rob h's Avatar
    May 2011
    Quote Originally Posted by drugowaz View Post
    Try different browser, like Explorer, chrome or Firefox etc.
  8. #1507
    drugowaz's Avatar
    Mar 2015
    Lithuania
    What external power supply or adapter is used to power up vvdi when read bmw f series engine ecus?
  9. #1508
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Because the internal regulators of the ECU require 12 volts of power at least 1 amperes to stabilize the voltage in the circuit
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
  10. The Following User Says Thank You to CarCity For This Useful Post:
    csavargo2 (20th March, 2018)
  11. #1509
    drugowaz's Avatar
    Mar 2015
    Lithuania
    No need to use 12v 1-2 amp adapter . Or bench power supply 12v to vvdi. Correct?
  12. #1510
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    ECU power supply from VVDI not directly
    and
    vvdi need to external power
  13. The Following User Says Thank You to CarCity For This Useful Post:
    drugowaz (10th October, 2017)
  14. #1511
    drugowaz's Avatar
    Mar 2015
    Lithuania
    i know that. im asking what suply to use to vvdi tool port . 12v 1-2 amp?
  15. #1512
    Oct 2017
    12V 1-2 amp is OK,no problem.
  16. The Following User Says Thank You to Xhorsesupport For This Useful Post:
  17. #1513
    Dec 2015
    LITHUANIA
    Can't read with vvdi prog cas3+ 0L15Y after update to 9395656, prog trying up to 98% and stop with error.
  18. #1514
    Quote Originally Posted by Deimis View Post
    check very well connections, I've read my car's CAS (cas3++) and 2 x6 m with cas3++ without any problem.
    Enviado desde mi SM-G955F mediante Tapatalk
  19. #1515
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Check your connections if needed try resolder the wires.
